Originally Posted by hawkcharmer
I just started noticing a noise coming from the front end left while backing up and turning the wheel. It also happens if I make a sharp left turn. Seems like a small knock or thump with a skipping feeling.
Any suggestions?
all of the boots look fine. no lift. regular driver
I'm thinking upper or lower ball joint, cv joint, inner ties?
but how can i narrow it down to one of these?
Any feedback greatly appreciated.
99 3rd gen 180,000
Have you checked that the sway bar end links are tight and not broken? Those will make a distinctive clunk sound like you've described.
You can test the ball joint and tie rods by lifting the truck (so the wheels/suspension are unloaded) and try moving the wheel (not spin it, but see if the assembly is loose in any direction).
LBJ: grab the wheel at 12 and 6 o'clock and try to move back and forth (push with one hand, pull with the other). Any shifting or movement would indicate your LBJ needs to replaced immediately.
Tie rods: (1) grab the wheel at 9 and 3 o'clock and try to move it like above. This will tell you if there is any play in either the outer or inner tie rod. (2) take the outer tie rod off the lbj assembly and if it doesn't support its own weight, the inner tie rod is shot.
2014 4Runner Trail Edition Premium - Magnetic Gray
2001 4Runner SR5 Thread...Sold
2010 Bernese Mountain Dog
1998 4Runner Limited: Smooshed on an icy bridge in MT
