03-03-2013, 08:01 AM
Should this hole in pipe be blocked?
Hey there,
The local mechanic guy here was fixing some things on my 4runner the other day and then saw this hole that he said needed to be blocked. (see photo attached) Currently you can feel air coming out of it. He said he would attached a short pipe to the hole and then block the end of the pipe.... does that sound right? I just want to hear your advice before he does this.
Thanks very much!
1998 4Runner SR5 V6 3.4
03-03-2013, 11:18 AM
Uh; no it should have a hose connected to it. Maybe the one in the red circle.
99 4runner SR5 3.4 auto, in the rebuild/build process
2wd to 4wd, SAS, 80 series LC axles and transmission
My Build, http://www.toyota-4runner.org/3rd-ge...ild-build.html____________________________________________
"The significant problems we face cannot be solved by the level of thinking that created them" Albert Einstein
03-03-2013, 11:54 AM
yeah looks like the hose laying down in the picture should be there, right now you have yourself a grandiose vacuum leak.
'99 Ltd 4x2
Some welders
03-03-2013, 12:01 PM
Well, it's not a vacuum leak but it's letting in unmetered air and will make it run very lean (lots of spark knock I would guess). Yes, there should be a hose attached to it, probably running to a valve cover.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
03-03-2013, 12:18 PM
ah yes, duh. no vacuum happening there yet but the unmetered air is just about as bad.
'99 Ltd 4x2
Some welders
03-03-2013, 12:26 PM
He said he can feel air coming out of it, so its not letting in ANY air, let alone not "un-sensored" air. It is air being pulled by the cold air intake system but isnt passing by the MAF sensor..
Are you assuming spark knock because you think "hot air" is being sucked in at that location, overheating the motor? Because as it blows outward, he should not have any noticeable symptoms of that hole.
2002 "Stormtrooper" 4Runner
Tacoma Bilstein 5100s | Eibach/Toytec Springs (Front) | FJ Springs (Rear) | Tundra 13WL Brake Swap | Much More...
Not to mention the fact that dirt and dust will enter your intake from there and kill your engine!!! Plug to now! That hose that is in the red circle is supposed to plug into that port. There needs to be a bung that has a nipple on it that attaches the hose to the intake tube.
'98 4Runner, 35" TTCs, E-Locker, 4.88 Yukon's, 3.4L, 5-speed, 3" Susp Lift, 3" BL, Elbow mod, Deckplate Mod, "D" gasket mod, 22" Magnaflow, 231mm Tundra Brakes, 67" TG Sliders, 8500lbs Portable Winch, Airlift Bags, Magellan GPS...
My Build Thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
03-03-2013, 07:12 PM
He is probably not feeling any air coming OUT of that hole because it is the intake line (there is NO pressure to blow OUT of the hole - it's sometimes hard to feel whether air is going in or out). At idle, it won't have much (if any) vacuum since it's before the throttle body, but it will have some vacuum when the throttle body is open, sucking in unmetered air (coming in AFTER the MAF) so the engine will be drawing in more air than the MAF says it is, making the mixture lean (the ECM calculate the amount of fuel to supply based on the amount of air being read by the MAF, which in this case is incorrect). The ECM will correct for that (using feedback from the O2 sensors) during normal driving but at WOT it will be lean, probably causing spark knock (detonation) and could damage the engine. It will probably also have a pretty rough idle and likely will 'hunt' (surging as it tries to get the mixture right with very little airflow).
03-03-2013, 07:14 PM
Real Name: Matt
Real Name: Matt
Block it off, stick a PVC cap in there and call it good. Everyone who does the ISR mod blocks this off anyway.
97 4Runner SR5 5 Speed Swap, ARB bumper - Warn M8000 winch - Custom rear bumper w/ tire carrier - Dual Jerry Can Carrier - Dual Optima Batteries - BlueSea Battery Isolator and Charger -Rear E-locker retrofit- ARB Front Locker - ARB Compressor - Hiflow exaust - ISR/deckplate mod - Trail Gear sliders - Tepui Kukenam Rooftop Tent - JDM Field Monitor Unit - 170 Amp Alternator - Bilstein 5125's - OME 861's - Toytec Coilovers - Camburg UCA's - 1" Toytec BL - 315/75/16 STT Pro's on Tacoma TRD wheels
03-03-2013, 07:51 PM
No you don't. The ISR mod hooks up the intake boot in front if this. This is still in place when you do the ISR mod.
As other have said, there is a plastic fitting that goes into the intake boot and that hose that is circled attaches to the fitting. Fix it. (And clean your engine too)
03-03-2013, 08:01 PM
Real Name: Matt
Real Name: Matt
Mine is definitely connected. even with the new intake. Hard to see, but you can see the tube connected to the intake pipe. In your picture, it looks like it is just laying to the side unconnected.
03-03-2013, 08:13 PM
Real Name: Matt
Real Name: Matt
My mistake, forgot there were 2 ports there. Had to go out and check for myself.
03-03-2013, 08:43 PM
Forgot to offer some advice, get a new mechanic.
03-04-2013, 04:58 AM
Hi, thanks for all the help. Indeed that other pipe just plugged straight back in.... 30second fix. I should have looked closer originally. Anyway, I'll see if that makes it run better... Seemed to be running fine, but going through a lot more fuel recently.
As for getting a new mechanic... we don't have much choice of mechanic where I am in Sierra Leone ... so with the help of this forum im slowly getting better at doing things myself. And the dirt gets cleaned off monthly... Another symptom of driving in Africa !
Thanks once again for the help
