Old 03-17-2013, 06:31 PM #1
madbomber08's Avatar
madbomber08 madbomber08 is offline
madbomber08 is on a distinguished road
Runnning a stock alloy wheel in the stock spare location?
First of all, I've got Tundra 231 mm brakes. The stock steelie spare will not fit on the front in the event that I would get a flat tire. This summer I'll be upgrading my tires to 265/75s and was thinking about getting 5 tires instead of 4, then including the spare in with the rotation every 3000 miles or so. I did some looking today, and it can be done, but the steel plate that holds the wheel/tire up will need to be grinded down a bit. Kind of sketches me out, especially knowing that I'm going to be putting more weight on the pulley assembly with a bigger tire. That being said, I am curious if any of you have fit a matching alloy wheel in the stock spare location?
So has anyone done this? Sound like a good idea or is it a waste of money to buy 5 new tires?
1997 4runner. Sr5. 5speed. 191k.
madbomber08 is offline   Reply With QuoteReply With Quote
Old 03-17-2013, 08:11 PM #2
tacojeff's Avatar
tacojeff tacojeff is offline
tacojeff is on a distinguished road
tacojeff's Avatar
I have a slightly deflated 33 stuffed in the stock location. I don't see why it wouldn't hold yours.
tacojeff is offline   Reply With QuoteReply With Quote
Old 03-17-2013, 08:35 PM #3
ugamurph's Avatar
ugamurph ugamurph is offline
ugamurph is on a distinguished road
ugamurph's Avatar
I can't answer your question about the alloy wheel, but....
I can assure you that a 265/75 will fit and the winch can handle the extra weight. I have Cooper Discoverer STTs which are much heavier than stock tires.
2001 Toyota 4Runner Limited 4WD w/ e-locker
Thunder Cloud, Armor by Budbuilt, Shrockworks & Stubbs
Superwinch Talon 9.5SR, Cooper Discoverer STT, Old Man Emu
ugamurph is offline   Reply With QuoteReply With Quote
Old 03-17-2013, 09:02 PM #4
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
The stock steel spare should fit the tundra brakes. Did you try it first?
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 03-17-2013, 09:18 PM #5
No I didn't try it. But according to BFAD's Tundra brake write up post #3 says the steel spare won't fit with the 13WL calipers.
To those of you with larger tires mounted in the stock location, do you just have them mounted to the steelie?
Old 03-17-2013, 09:24 PM #6
white_n_slow's Avatar
white_n_slow white_n_slow is offline
white_n_slow is on a distinguished road
The weight should be no problem. I ran a 33x12.5 KM1 under the back of my 60, which had a spare tire holder of the same design as the one in our 3rd gens, just older and more rusty. I even used it as a "rubber skidplate" a few times with no problems
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
white_n_slow is offline   Reply With QuoteReply With Quote
Old 03-17-2013, 10:06 PM #7
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
The 265 will fit under the truck. Easy.
The only part I'm concerned with is why would you want to put a STOCK ALLOY under the truck? These rims are already 14 years old, putting it under the truck is asking for something to scuff the shit out of it, or worse.
If you want to put a 265 indter the truck, have it mounted on the spare rim. That way it doesn't ruin the rim the way it would an alloy.
Just my .01.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 03-17-2013, 10:19 PM #8
My thoughts were to throw the spare in with the tire rotations. I don't want to rotate the tires with the stock steelie, that just looks bad. Maybe once the time comes to get new tires I'll look for a used 265 tire. I've been warned against running a smaller tire against the rest....
Old 03-17-2013, 11:15 PM #9
afg10000's Avatar
afg10000 afg10000 is offline
afg10000 is on a distinguished road
afg10000's Avatar
I learned a valuable lesson with the spare tire and super awesome rim that's provided. Needless to say, I immediately gots an OEM alloy off of ebay for $35. Put a 265/75 on it and made sure all is in good shape. I do not rotate the spare with my regular drivers (Duratracs), but I always check it. It's kind of like forgetting to lock your front door...you only do it once-
'96 Limited - Locker - 127k- totaled out -
'01 Limited 175k - sunken and resurrected - stock, other than TBU 231mm
'98 Limited - Locker -158k-Bilstein 5100 Tacos- Toytec/Eibach 3" lift coils- diff drop-265/75/16 Duratracs -OME 890's-Bilstein 5125's, panhard bar drop, TBU 231mm, Spidertrax 1.25' spacers, Savage sliders, 2nd gen SC/URD 7th, JBA exhaust, HID retrofits -
afg10000 is offline   Reply With QuoteReply With Quote
Old 03-17-2013, 11:49 PM #10
Omaha! I'm over in lincoln. Its not to often you see someone from NE.
Anyway, back to the spare tire. So you do indeed have a 265 with a stock alloy mounted in the spare location? How did you modify the bracket to fit the alloy?
Old 03-18-2013, 12:15 AM #11
BigFishAllDay's Avatar
BigFishAllDay BigFishAllDay is offline
BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about
I've tried it, and I'm 100% certain the stock steel spare will NOT clear the Tundra 231 calipers. I have not tested the stock spare for clearance on the 199's.
Trust what's in the thread, I verified it before posting. Also, I purchased a stock 4th gen alloy for my Wife's 4Runner and we're running it under the truck in the stock location w/no issues. The 4th gen wheel is a 17" wheel, with a 265/65r17 tire. Compared to a 265/70r16 (the size of the other 4) the 17 inch setup is within 1% in terms of size. I expect this to work perfectly as a spare w/the 231mm Tundra brake setup.
Read more here:
http://www.toyota-4runner.org/3rd-ge...ml#post1164674
Also, this thread might help w/deciding whether or not a 265/75r16 will fit under the rig. Should be no problem at all.
http://www.toyota-4runner.org/3rd-ge...pare-tire.html
2001 SR5 Sport Ed. S/C'd V6 Auto 4wd (< Click for Build) ....everything but a kitchen sink (it's on the "to do" list)....
2003 Tacoma SR5 S/C'd V6 5-spd 4wd (< Click for Build) ....boost, armor, lockers, gears, etc....
2008 Sport Ed V6 Auto 4WD (< Click for Build) ....the Grocery Getter OEM+ build....
My Write ups: T-Case Leak? - 231mm TBU - Rear Axle Seals - Trans. Cooler Install - Suped Up Air Comp - Big 3
BigFishAllDay is offline   Reply With QuoteReply With Quote
Old 03-18-2013, 07:19 AM #12
ugamurph's Avatar
ugamurph's Avatar
Mine is on the stock steel spare wheel. Same as you, I plan to get a matching spare wheel so I can do 5 tire rotations.
Originally Posted by Doc2012 View Post
The only part I'm concerned with is why would you want to put a STOCK ALLOY under the truck? These rims are already 14 years old, putting it under the truck is asking for something to scuff the **** out of it, or worse.
You can put the spare in so that the outside of the wheel faces up to keep it from getting scuffed up. That would also eliminate problems (if there are any) with the winch bracket fitting the alloy wheel.
It's unlikely that your going to damage your spare. But, we all know that damage can occur on the trail. We accept that when we decide to go wheeling.
Old 03-18-2013, 08:49 AM #13
Singtoe's Avatar
Singtoe's Avatar
Run wheel spacers and save your self the head ache.
I put the tundra brakes but ran wheel spacers too so I never had any problems
I know this. If you put an Alloy wheel under a truck and let road salt sit on it for any duration, it will look like kaka.
Old 03-18-2013, 08:54 AM #14
A.Wilson013's Avatar
A.Wilson013 A.Wilson013 is offline
Real Name: Alex
A.Wilson013 will become famous soon enough
Real Name: Alex
I run a matching spare alloy with no modifications. It's a 265/70/17 on a tundra 17" wheel. I don't rotate it in- mostly because I am lazy. I take it out every now and again (couple times a year) and clean it up / check pressure.
You shouldn't have any issues...
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
A.Wilson013 is offline   Reply With QuoteReply With Quote
Old 03-18-2013, 10:15 AM #15
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
thats where my 5th FJ wheel is as well.
Stick Figure is offline   Reply With QuoteReply With Quote
Max Spare Tire Size, Stock Location BlackWorksInc 4th Gen T4Rs 22 03-02-2022 09:03 PM
WTB Stock Spare Wheel Brentif For Sale: Suspension/Wheels/Tires 3 11-21-2012 07:51 PM
I got my full size 285 spare to fit in stock location Spish 3rd gen T4Rs 1 09-19-2011 11:00 PM
Shadow Mica SE Hood, Silver SR5 Hood, SE spare wheel tire, Center console, stock susp whoosh Classifieds - buy & sell (no commercial ads please) 7 08-11-2009 07:06 PM
WTB 2000 stock alloy wheel CSL Classifieds - buy & sell (no commercial ads please) 0 01-11-2009 01:46 PM
