Old 03-20-2013, 09:19 AM #1
imanabsolutezer imanabsolutezer is offline
imanabsolutezer is on a distinguished road
Vibration/Rubbing when accelerating?
It started this morning, on the way to work. I can not tell if it is vibration or rubbing, but it seems to happen when accelerating, both at high speeds and at low speeds. I am not sure if I can feel it, but I can definitely hear it, and it sounds like it is coming from the front, passenger side. I pulled off and looked under the vehicle, nothing hanging or seemingly out of place, same with under the hood, though I am not a trained mechanic.
Loose belt?
Haven't been changed in a couple of years.
Wheel problem?
Only issue after last alignment was rear, drivers side wheel and it was only off by a very little.
Exhaust?
Any questions that I could answer to help identify the problem, or tell a mechanic would be a tremendous help. Using the search is difficult because it is hard to place right now. I will update with any relevant information I come across.
2000 Champagne 4Runner Limited. 95,000mi
Stock
imanabsolutezer is offline   Reply With QuoteReply With Quote
Old 03-20-2013, 10:59 AM #2
jaybee's Avatar
jaybee jaybee is offline
jaybee is on a distinguished road
jaybee's Avatar
sounds like your wheels r not balance...u need to rebalance then...maybe some weight came off...or also wheel bearing....
jaybee is offline   Reply With QuoteReply With Quote
Old 03-20-2013, 11:54 AM #3
smkd13's Avatar
smkd13 smkd13 is offline
Real Name: Ben
smkd13 is on a distinguished road
smkd13's Avatar
Real Name: Ben
Don't forget wheel bearings. But and like this guy said^^^ get balanced. Running around in a truck that vibrates like that will literally shake things loose. Not safe so get it fixed ASAP.
smkd13 is offline   Reply With QuoteReply With Quote
Old 03-20-2013, 12:40 PM #4
It does not shake the wheel, like the usual unbalanced wheel would.
Stock
Old 03-20-2013, 02:00 PM #5
smkd13's Avatar
Real Name: Ben
smkd13's Avatar
Real Name: Ben
Ok so you would also need to look at other components of your drive train. CVs, driveshafts, pinion angles, loose joints (upper and lower balls), engine mounts, etc. replace your belts if just for safe measure.
If you take it to a mechanic just have them do a ride along so you can show them what it is doing and they would be able to tell you more specifically what it is. You could take stabs at this all day and never find the culprit. If your takin it to a shop just do so.
Old 03-20-2013, 02:54 PM #6
jaybee's Avatar
jaybee's Avatar
drive shaft has bolts in both ends..make sure there tight and not lose...
Old 03-20-2013, 07:22 PM #7
Kurtis's Avatar
Kurtis Kurtis is offline
Kurtis is on a distinguished road
Kurtis's Avatar
Loose belt?
Wheel problem?
Exhaust?
Vibrations under acceleration normally indicate a bad U-Joint and can transmit the vibrations up the drivetran very well.
My Junk
Kurtis is offline   Reply With QuoteReply With Quote
Please help, Vibration only while accelerating. toddsemail1977 3rd gen T4Rs 28 10-27-2022 12:32 PM
Jolts when accelerating? NathanOfSeattle 3rd gen T4Rs 16 12-04-2011 12:24 AM
Jerks when accelerating 75206 3rd gen T4Rs 3 03-29-2010 09:11 PM
Accelerating darktiger Problems & Warranty Issues 13 09-07-2005 02:05 PM
hesitation accelerating hendy 3rd gen T4Rs 4 08-22-2005 05:28 PM
