Old 03-20-2013, 07:43 PM #1
a4runner97's Avatar
a4runner97 a4runner97 is offline
a4runner97 is on a distinguished road
a4runner97's Avatar
Water build up in my passenger side floor and behind passenger seat
hi,
as stated there is water build up in my passenger side floor and behind passenger seat (might just be moving back there) but i was checking all the drains they seem clear. I can't seem to find the A/C condenser drain pipe/tube that goes through the firewall. could someone tell me where its located possible post some pictures if its not a hassle?
the water also doesnt smell like coolant just musky so its not the heater core (i hope)
Thanks in advance!
1997 4Runner Limited | retrofit projectors | Tundra TRD front coils, adjustable bilsteins, 861ome with black tokico lc shocks in the rear with a 1 inch body lift | aluminum rims with 4" BS | 315 75 r16 duratracs | 231mm tundra brakes | front savage bumper, custom rear tire swingout | 1/4inch front skid 1/8th belly | custom rear lower control arm skids
a4runner97 is offline   Reply With QuoteReply With Quote
Old 03-20-2013, 08:04 PM #2
a4runner97's Avatar
a4runner97's Avatar
I forgot there's a heater core under the passenger seat too... But the rear heater hasn't been turned on could it still leak if it hasnt?
Old 03-20-2013, 08:50 PM #3
nissanh nissanh is offline
drain line
Drain is indicated by the arrow. IT may be clogged or misaligned.
Water build up in my passenger side floor and behind passenger seat-dscn3638-jpg
Old 03-20-2013, 09:20 PM #4
a4runner97's Avatar
a4runner97's Avatar
Thanks! but could you also possibly show me a picture of the drain from the outside from under the yota? i want to try and clean it out but i cant find the exit tube...
Old 03-20-2013, 09:39 PM #5
a4runner97's Avatar
a4runner97's Avatar
The foam there is bone dry... What other leaks could I have that is making my passenger floor and rear passenger floor wet?
Old 03-20-2013, 11:23 PM #6
PitbullRescuer's Avatar
PitbullRescuer PitbullRescuer is offline
PitbullRescuer is on a distinguished road
Sun roof drain?
'98 SR5 4x4, cheap DD http://www.toyota-4runner.org/3rd-ge...im-addict.html '99 SR5 Highlander 4x4/5 Speed... http://www.toyota-4runner.org/3rd-ge...eed-build.html '97 SR5 4x4/5 speed, another new project... http://www.toyota-4runner.org/3rd-ge...new-build.html '00 SR5 4x4, new project, stay tuned... http://www.toyota-4runner.org/3rd-ge...ld-thread.html '97 Limited 4x4, freshened up quite a bit... http://www.toyota-4runner.org/3rd-ge...d-3rd-gen.html '99 SR5 Highlander 4x4... http://www.toyota-4runner.org/3rd-ge...ce-thread.html
PitbullRescuer is offline   Reply With QuoteReply With Quote
Old 03-21-2013, 12:03 AM #7
4x4mike 4x4mike is offline
4x4mike is on a distinguished road
Could also be the access hole in the fire wall. Pop the hood and you'll see a giant snake of wires in a rubber boot that enters the cab on the passenger side. If you've recently had a car wash or rain water can sneak through there. Not totally sure how to seal it but it might be worth a look.
Another spot I hear of is the inlet vent in the cowl under the windshield. Turn on the defrost and walk around the truck to that side and listen to the air being sucked in in that spot. Apparently something separates and can enter the cab.
I just know this because I get a wet spot under my passenger floor mat but is only rarely and I've had trouble tracking it down.
4x4mike is offline   Reply With QuoteReply With Quote
Old 03-21-2013, 09:42 AM #8
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
Have you been around a lot of dust or dirt lately? Once when I was camping, dust clogged up my condensation drain and caused water to back up on my passenger side floorboard. It was a lot of water. The drain tube can be found by removing the passenger side engine bay skirts. Facing the engine, you should see it on the left. Just find something that is flexible and small enough yet sturdy so it makes it's way pass the bend.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 03-21-2013, 09:55 AM #9
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
Regarding the potential of a leak from the rear heater, the moisture would contain anti-freeze.......it would be green (or whatever color anti-freeze you are using) and smell sweet. Condensation from AC or drain from sunroof should be relatively clear water.
Good Luck....
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 03-22-2013, 12:08 AM #10
a4runner97's Avatar
a4runner97's Avatar
so pretty much narrowed it down... I turned on my heat full blast and cranked it didnt get hot. And underneath the carpet there was a rubber mating that i didnt see before and when i lifted it up it was soaked, it was where all the liquid was coming from and greenish in colour on the insulation but clear liquid came out when it squeezed the insulation
im going to say its a heater core clog/ or malfunction Anyone know any write ups on how to remove the dash and remove the heater core?
I also took compressed air to the a/c drain tube to be safe so ill give it a week before ripping out the heater core.
Thanks.
Old 03-22-2013, 11:33 AM #11
Did you tried it when the engine was hot? How is the coolant level in your radiator (Caution: open the radiator cap only when it is COLD)?
Heater core removal
Old 03-23-2013, 04:07 AM #12
a4runner97's Avatar
a4runner97's Avatar
so my heater temperature gauge cable was unhooked at the bottom of the dash... so that was the reason of having no heat. but the last owner might have unplugged it to stop coolant leaking into the cabin.
I guess i have to take the heater core out and examine it. unless by chance the heater link was disconnected by accident and the leak is whole different problem....
thoughts? A/c seems to be working and there flow out of the drain pipe.
there was a thunder storm and i parked outside and drove in it and no extra leakage. Im just frustrated it could be so many things....
Old 03-23-2013, 01:48 PM #13
fightman80's Avatar
fightman80 fightman80 is offline
fightman80 will become famous soon enough fightman80 will become famous soon enough
fightman80's Avatar
All very plausible scenarios... but did you happen to look at the sheet metal around your windshield in that area? Any stains on your headliner? I had some mild rust bubbles around my windshield... and as a result, the windshield would leak. My passenger floor board was soaked with rain water....
Just another idea for you to ponder.....
1998 4Runner SR5, ISR and Deckplate Mods, Painted Intake Manifold, TRD Tundra Struts, Diff Drop, LC 8 Wraps w/ Skyjacker shocks, Panhard Drop Bracket, Rear Tire Carrier, Maxxis Bighorns, Procomp Wheels, Custom Front Valance, Sport Edition Skidplate, Upgraded Exterior lighting
fightman80 is offline   Reply With QuoteReply With Quote
Water leaking in on passenger's side dakine_999 4th Gen T4Rs 4 10-17-2012 02:45 PM
Water leak on passenger side Bri///M Classic T4Rs 5 06-15-2010 01:24 PM
water in passenger side? 96runnerOME 3rd gen T4Rs 15 06-10-2010 10:47 AM
Passenger Side Headlight has water in it and....... eskimochaos 4th Gen T4Rs 4 12-21-2009 12:13 AM
