Originally Posted by nissanh
Rebuilt engines will run about 100-150 K miles and will start burning oil after that.
If you check the compression on a rebuilt and a good used engine, the used engine will show better compression. I rebuilt a 3L hilux engine with genuine toyota parts, yet, it takes extra turn or two to start over a used (JDM) engine.
I would suggest you stop giving flat-out false advice such as this. An engine that is rebuilt properly, can last just as long or longer than a factory built engine.
Properly rebuilt is the key.
There are people out there "rebuilding" engines, that are barely qualified to change oil. Obviously an engine that is "rebuilt" by one of those clowns, will not last like a properly rebuilt engine.
