Old 04-01-2013, 09:18 PM #1
Stuntmonkey Stuntmonkey is offline
Stuntmonkey is on a distinguished road
Trans issue
Hi all,
Picked up a 97 Limited this week. 110k miles, super clean, just a few scratches on the flares from some retarded driving.
Only issue I have, is when the truck is cold, when you select drive, it doesn't engage until you give it a little gas and you get a jerk forward, and you're off.
Never happens when the truck is warm. Fluid has been changed twice in the last 3 months, hasn't been leaking and there is no evidence of pink milkshake.
Any advice before I go and drop this off at a dealer to get the trans serviced?
Thanks!
Stuntmonkey is offline   Reply With QuoteReply With Quote
Old 04-01-2013, 09:30 PM #2
chadsy chadsy is offline
chadsy is on a distinguished road
how is your ebrake?
1996 4Runner SR5 4x4 / 275,000 Miles / All Stock
chadsy is offline   Reply With QuoteReply With Quote
Old 04-01-2013, 09:33 PM #3
Seems to be working fine?
Old 04-01-2013, 09:44 PM #4
koulee koulee is offline
Banned
koulee is on a distinguished road
Banned
Might be a solenoid problem. Can you feel the transmission shift into gear or does it not shift at all?
koulee is offline   Reply With QuoteReply With Quote
Old 04-01-2013, 09:54 PM #5
Sometimes I can feel it, but then sometimes it feels like it shifts when you hit the gas.
Old 04-01-2013, 10:00 PM #6
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
I'm assuming you meant to say it never happens when the truck is warm. Next time it happens shift down to Low and see if it will move right away then. If it still acts the same I'd check the rear brakes for gear lube first before digging into the trans. Although, the lube in the rear brakes problem doesn't normally cause this unless it's really cold outside. How cold is it in Vancouver?
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 04-01-2013, 10:03 PM #7
Jc12's Avatar
Jc12 Jc12 is offline
Jc12 is on a distinguished road
Jc12's Avatar
it was 17 degrees today! yes i would definitely dig more into if it does shift into gear at all/ever until the gas is hit, then it will be much easier to filter the problem
2001 4runner SR5 / 170KM / Bilstein 5100 with stock coils & OME906 / toyo 265/76/16 / 1.25" spidertrax
1997 S/C 4runner / 276km / 3" OME lift / 285-75-16 duratracs / rock crawler's
SOLD
1999 limited 4runner / 255km / 4" LC lift / 285-75-16 pro comps / and a million dollars in mods
SOLD
Jc12 is offline   Reply With QuoteReply With Quote
Old 04-01-2013, 10:07 PM #8
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
Originally Posted by Stuntmonkey View Post
... Any advice before I go and drop this off at a dealer to get the trans serviced?
Thanks!
Yeah, get several opinions. If you just "drop this off at a dealer to get the trans serviced" your going to get reamed. And I don't mean opinions from AAMCO and the like.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 04-01-2013, 10:08 PM #9
kball's Avatar
kball's Avatar
^ 17 deg... I think the OP should be looking at his rear brakes then. Leaking axle seals may be the culprit.
236K miles
Old 04-01-2013, 10:32 PM #10
He means 17 degree Celsius. So 63f. And yes, sorry, meant it never happens when she is warmed up.
I'll definitely shop around and get opinions/quotes from places, they don't call them stealerships for no reason!
Old 04-01-2013, 10:45 PM #11
kball's Avatar
kball's Avatar
Ok gotcha, so most likely not the rear brakes freezing up on you. Try the shift to Low and see if that makes a difference. If so it's probably a solenoid sticking.
236K miles
Old 04-03-2013, 04:31 PM #12
Seems like it must be a solenoid issue. Shifts fine from low and 2.
I'm now wondering what the replacement solenoid is, and where it's located. Accessible I hope haha.
Old 04-03-2013, 07:01 PM #13
Try the "drain and fill" method in 300 mile intervals. It could be you have old ATF fluid. This seemed to remedy a problem I was having similar to yours.
99 SR5 Auto trans issue... no overdrive dariusriley 3rd gen T4Rs 5 08-21-2016 02:54 PM
Should I avoid a rig, if had strawberry trans, and trans was replaced?? Woodsie8 3rd gen T4Rs 4 03-25-2012 09:20 PM
trans gone at 67K!!???!?!?! Bacon Problems & Warranty Issues 8 03-17-2009 07:40 PM
Trans MikeFromShiloh Classic T4Rs 1 11-28-2006 04:05 PM
'95 2nd Gen 4-Runner Trans Issue rd-daze Problems & Warranty Issues 7 05-27-2004 11:15 PM
