Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 04-03-2017, 03:47 PM #61
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
Originally Posted by JWaldz View Post
I have a '99 and mine are the flanged bolts. Never had any issues with them. But, to answer your questions, I believe the bolts with washers are the "newer" version.
Originally Posted by Merninater View Post
There is a decent bit of unclarity due to these bolts. I will most likely just go with the washers.
I used the ones with the washers on my 97. I checked and cross referenced part numbers and couldn't find any convincing reason why the bolts with washers couldn't be used. The LBJs are the same and so are the knuckles through the years.
Properly torqued up with blue Loctite — no problems so far.
Here is a recent thread on this subject that i posted some screen shots of the part # in.
Umm..did I receive the correct LBJ bolts?
"Variety is for your mind, not your body " —OS
StreetCreeper is offline   Reply With QuoteReply With Quote
Old 04-03-2017, 05:07 PM #62
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
@StreetCreeper
So I guess the flanged bolts go to the '96-'00 while the bolts w/ washers were the updated and suggested part for the '01-'02 AFTER the recall.
I think it's probably safe to say it's likely better off just to get the flanged bolts.
The only difference I can honestly tell is the torque setting between the two.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 04-03-2017, 06:18 PM #63
Real Name: Woody
Real Name: Woody
@StreetCreeper
Yeah I think the differences if any are so minor as to not be an issue. I would think if there was any real concern — Toyota would have made it more obvious that one style be used over the other for any particular LBJ.
I'm not losing any sleep over using the new style on my 97.
Old 04-08-2017, 12:11 PM #64
Merninater's Avatar
Merninater Merninater is offline
Merninater is on a distinguished road
Merninater's Avatar
@StreetCreeper
So I went with the bolt/washer ones. My 02' has 210k on it and it had the recall done at 50k miles. The bolts that went in during the recall service were the bolt and washer ones so I picked up some new bolt and washer ones again. You commented on the torque setting... I did not know it changed? I am not totally sure what torque setting to use with these bolt/washer ones into the new LBJ.
2007 4Runner Sport V6 4WD | 120K miles
2010 Lexus RX 350 4WD | 180K miles
2012 Rav4 Limited V6 4WD | 120K miles (sold)
2002 4Runner SR5 V6 4WD | 270K miles (sold)
Merninater is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 01:37 AM #65
Fore_Play4R Fore_Play4R is offline
Real Name: Joe C
Fore_Play4R is on a distinguished road
Real Name: Joe C
Good looking out with this list brothas, looking into replacing ball joints and inner/ outer tie rods
Fore_Play4R is offline   Reply With QuoteReply With Quote
Old 11-17-2020, 03:37 PM #66
mado0013 mado0013 is offline
mado0013 is on a distinguished road
2001 - 203k -
Hey,
Just bought my first one, looking for doing all of this as well, did you already did it according to that list?
you find everything you needed?
anything changed or uneeded?
thank you
mado0013 is offline   Reply With QuoteReply With Quote
Old 11-25-2022, 11:20 AM #67
Dougal Dougal is offline
Dougal is on a distinguished road
For 2000 4runner LBJs does the package 04005-02235 contain both Left Side 43340-39465 and Right Side 43330-39585 ? (I realize the package has 2 LBJs I'm assuming these 2 parts ?)
I guess also
+ 8X 43340-39465
+2X 90171-A0005 ?- Not sure if these are needed?
do I need to purchase cotter pins separately?
Cheers,
Dougal is offline   Reply With QuoteReply With Quote
Old 11-25-2022, 05:24 PM #68
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I guess also
+ 8X 43340-39465
Cheers,
04005-02235 contains a left and right lower ball joint but does not come with castle nuts (90171-A0005) or cotter pins. You'll need 8 of either 90080-10066 (96-00)(59 ft/lb), 90119-10933(01-02)(37 ft/lb). You can use the 90119-10933 without any issues, and a recent study/testing has shown that bolt to be better than 90080-10066. Just be sure to torque it to the correct value.
Old 11-25-2022, 09:39 PM #69
Thanks
RE 04005-02235 contains 2 LBJs I just can find the individual Part #s in the packaging....
Looking at other threads for 3rd Gen
1996-2000 use a flanged bolt Part #90080-10066
2001-2002 use a bolt and washer Part #90119-10933.
When I put 90119-10933 for my 2000 3rd gen VIN it says not compatible.....
Bloody cotter pins - well I'll have to find some that fit.... does anyone have a spec or Part # for the cotter pins,
Cheers,
Old 11-26-2022, 07:57 AM #70
Apparently the cotter pins are 5/32... so generic I guess works... does material matter ?... silly question I guess but I was going to pick up stainless steel ....
Old 11-26-2022, 09:53 AM #71
Real Name: Patrick
Real Name: Patrick
Thanks
Cheers,
Either bolt part number works. Generic cotter pins are fine and material doesn’t matter. Just make sure that they are long enough to fold back over
3rd Gen: Lower ball joints, Tie rods, boots, sway bushings. NEW!! djbrand1 For Sale: T4R Items 15 04-01-2013 12:46 PM
3rd Gen: Lower ball joints, Tie rods, boots, etc. NEW!! djbrand1 For Sale: Suspension/Wheels/Tires 8 03-26-2013 10:56 AM
Front End Replacements (tie rods, ball joints etc) jay4runner Maintenance/Detailing 1 07-11-2012 09:07 PM
Questions: Clicking CV axle, leaky outer tie rods, leaky ball joints, etc. econhonda 3rd gen T4Rs 3 05-16-2011 08:25 PM
Ball Joints, Bearings, Rear End Sag buddy10mm Classic T4Rs 0 11-03-2008 02:42 PM
