Originally Posted by 4x4mike
I have a 6 slot Blue Sea aux fuse box behind the dash. It is fed from the battery and makes installs of accessories safe and easy. I'd look into something like this if you plan om future mods. My 6 slots are full with gps, phone usb, rocklights, driving lights, ham and cb.
With a low draw device you can tap into the radio harness or power outlet. You need to decide if you want constant power or switched. You need to also tap in and ground well to insure both devices work well.
If it is tapped into the radio it will switch off with the truck correct? I'll look into the Blue Sea fuse box, I do plan on future mods like aux lights.
