Old 04-15-2013, 03:37 PM #1
tm1579 tm1579 is offline
tm1579 is on a distinguished road
4runner' 99 won't start for 1st,2nd,3rd but eventually will start the engine
When I tried to start my 4runner' 99 it won't start for 1st,2nd,3rd ... time but eventually will start the engine. It happens very frequently.
For example: If the car starts after a couple of tried (turn the key to start position 5 times) then I drove for 5- 10 minutes then I stop the car and the same cycle happen again.
1- When I turn the ignition ON before starting the car:
- The lights come ON in the instrument panel.
- The "Check engine" light come on
2- When I turn the ignition key to "Start" position nothing happens, the starter won't crank.
3- I just change battery couple month ago
What could cause the "No start no crank problem"?
- anti-theft system?
- ignition switch?
- starter ?
- starter solenoid?
I appreciate your help,
Toan
tm1579 is offline   Reply With QuoteReply With Quote
Old 04-15-2013, 04:50 PM #2
ICD's Avatar
ICD ICD is offline
ICD is on a distinguished road
ICD ICD is offline
ICD's Avatar
Couple things
1. Check your terminals on your battery, and take note on what type you have. Some don't like having those green/red corrosion rings.
2. We have a know starter issue and at times needs the starter contacts replaced.
99 4Runner Limited 2WD
ICD is offline   Reply With QuoteReply With Quote
Old 04-15-2013, 05:39 PM #3
farmerjon's Avatar
farmerjon farmerjon is offline
farmerjon is on a distinguished road
farmerjon's Avatar
Starter contacts would be my bet. My rig, around 100K, started having issues starting. Would try a few times and then would start. Eventually, it just stopped starting. Replaced the contacts, and now am good to go, starts every time!
1998 T4R SR5 Natural White 4WD 5VZ-FE-V6-3.4L / ARB / Subaru-Hilux Gauge Pack / 199mm TBU / BFG All-Terrain KO2 265/70/R16
Build Thread. T4R & adventure photolog.
farmerjon is offline   Reply With QuoteReply With Quote
Old 04-16-2013, 12:54 PM #4
Hi ICD,
Thanks for the quick help, I checked the battery connector it tight, cleans and no corrosion. You mention starter contacts replaced? it is not the starter, right? The starter is the original, well, 14 years not change yet so
Thanks very much,
Toan
Old 04-16-2013, 01:06 PM #5
Hi farmerjon,
So maybe it is not the starter but the starter contact?
Is easy to replace starter contact? if not how much is cost to repair?
I saw a thread here, is this the one you talking about?
(Another) Starter Contacts Removal Thread!
Thanks,
Toan
Old 04-16-2013, 01:14 PM #6
JSwain's Avatar
JSwain JSwain is offline
Real Name: Swain
JSwain is on a distinguished road
JSwain's Avatar
Real Name: Swain
Disconnect your battery, then disconnect the starter power wire & clean it so it looks like new with sandpaper, also do the ground that goes to the engine block. Reconnect everything and start it up.
96 4Runner - 2.7L - 5Spd - AEM Intake - 32" BFG's - Radflo 2.0 in front LC/Bilstein in back
SS Adj. Panhard - Daystar Supersoft bumpstops - Homemade Bumper
JSwain is offline   Reply With QuoteReply With Quote
4runner' 99 , no start no crank problem
93 4runner won't start w/ check engine light 2nd-gen-user93 Classic T4Rs 6 11-23-2012 10:53 PM
2000 4runner wont start without clutch start cancle jmcgahran 3rd gen T4Rs 3 08-29-2011 12:27 PM
92 4runner v6 4wd engine cranks wont start ninja309 Classic T4Rs 5 03-29-2011 02:54 PM
Why doesnt my 4runner start when its cold...it will start with some gas pedal 96boo2 3rd gen T4Rs 1 03-07-2007 10:56 PM
95 4runner cold start NO START UrbanAssult Problems & Warranty Issues 0 02-06-2005 11:53 PM
