04-21-2013, 12:56 AM
Question about 5vzfe
My neighbor bought a 03 tacoma v6 5vzfe with 89K miles. When we bought it we notice the temperature needle comes slightly below 3/4 in the gauge (usually it should be below 1/2). Radiator is still factory. After running about 15-20 minutes, I noticed the lower radiator hose is still cool. Can this be due to a clogged radiator?
We cleaned the MAF sensor, intake hose, throttle body and air filter box (had a K&N filter and oil over the intake system!)
Idle RPM stays about 1200 when the engine is hot, and when the AC is turned on, the RPM drops to about 1000.
Any idea what's wrong?
04-21-2013, 02:10 AM
bad thermostat?
'99 Limited, Millennium Silver, E-Locker
Front: '99 Tall Springs, Tundra Bilstein 5100's @ 5th perch, 3/8 in. Top plate spacer, Light Racing/SPC UCA's, 1.25in wheel spacers, sway end links from 2nd gen rear
Rear: Toytec Superflex, 05'+ Tacoma Bilstein 5100's, extended bump stops, extended brake line, e-brake strain relief bracket, 1.25in wheel spacers, front sway bar links, ES sway bushings
Other stuff: 1/2" body lift, B&M tranny cooler, extended rear diff breather, deckplate, blue-wire mod, ARB Tacoma BullBar, Smittybuilt XRC8 winch, 285/75/16's
04-21-2013, 05:38 AM
Banned
Banned
At 89k miles, if it hasn't had the timing belt done, then it is time to have it done. Just replace all of it and see if it still happens and go from there.
04-21-2013, 09:23 AM
Real Name: Ed
Real Name: Ed
Originally Posted by curtperry
bad thermostat?
Sounds like it to me,since he mentioned the cool radiator hose
04-21-2013, 09:47 AM
What makes you think something is wrong? It might be just an out of calibration gauge. What happens when he drives it under a load. Does the temp gauge stay the same. If it does, then nothing is wrong. Stop being a hypochondriac.
FWIW- My volt gauge reads almost at top but my multimeter says 13.8 volts...
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
04-21-2013, 10:56 AM
Curtperry, I suspect thermostat too. No T-belt replacement sticker anywhere in the engine bay so sometime soon I am going to replace the T-belt and the other components.
Since it is an automatic, isn't it better to replace the radiator like in every 10 years?
Singtore, I did use a digital IR thermometer to check the temperature at the output hose at the metal pipe and was 82 Celsius (179.6 F). I forgot the lower radiator hose temp. Yes, after driving 60 miles at 60 MPH, the gauge stays the same.
What do you think about the high RPM? IS this normal after cleaning a dirty MAF sensor?
Thanks
04-21-2013, 11:18 AM
Thanks
I don't get it.
The temperature was reading below normal and you still want to fix it.
As for the high idle. Check all the vacuum hoses for leaks.
04-21-2013, 11:50 AM
Location: Stationed in Camp LeJeune, home is Conover, NC
Sing, this is why he's questioning it.
How's the heat in the cab?
That's the #1 sign of a bad thermostat.
It should be hot, not warm. I it's not hot, then change the stat. If its fine, leave it be. Probably a bad gauge.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
04-21-2013, 12:04 PM
Singtore, it is 3/4 from the bottom or 1/4 from the top.
DOC2012, you mean the heat in the cabin? Heater works fine.
OK, I'll try the thermostat.
Back to RPM.... There are only 2 vacuum hoses connected, one to the air filter box and one to the box attached right in the middle of the main intake hose. All in place. I just sprayed the throttle body cleaner and wiped the gunk off the throttle body with a paper towel (didn't use a tooth brush).
04-21-2013, 12:55 PM
Real Name: Matt
Real Name: Matt
Idle RPM is 1200??? And when AC is on its 1000? That seems very high! My idle RPM after the engine has warmed up is around 650-700. Plus, I NEVER run my AC, even if its 103 out! hahaha. I would check all vacuum hoses and the intake.
04-21-2013, 01:05 PM
The RPM is crazy high. There's got to be more than 2 vacuum lines. There has to be.
Check the throttle linkage as well. See if it was adjusted at all.
What I mean by the heat in the cabin is just what I said. Lol.
With the heater ON, is the heat HOT, or just warm? If its just warm, it's probably the thermostat.
04-21-2013, 02:41 PM
Real Name: Swain
Real Name: Swain
Remove your throttle body and clean it very thoroughly including the sensors and that should fix your high idle. Check voltage at your battery with it on/off and make sure it is in spec 13.8+ on, 12.8~ off. Clean any dirty grounds, and check/clean the connection for your coolant temp sensor. If your thermostat was stuck shut the truck would constantly go up in temperature, unless your coolant looks very dirty I wouldn't bother opening up the system.
96 4Runner - 2.7L - 5Spd - AEM Intake - 32" BFG's - Radflo 2.0 in front LC/Bilstein in back
SS Adj. Panhard - Daystar Supersoft bumpstops - Homemade Bumper
04-21-2013, 05:23 PM
I must be a complete idiot. if the top hose is hot and the bottom hose is cooler, then what is the radiator doing?
So again. What is the problem? You even said the temperature was 179.6 F. What do you want it to read?
04-21-2013, 06:51 PM
Banned
Banned
Could also be the sensor that the gauge gets its reading from. I had an older Camry that had a bad sensor that pegged the temp gauge at max until I fixed it.
04-21-2013, 08:56 PM
Real Name: Swain
Real Name: Swain
Cooling???
