Old 04-21-2013, 04:59 PM #1
4RUN0326 4RUN0326 is offline
4RUN0326 is on a distinguished road
Valve Cover Gaskets
Hey guys Im loosing about a 1/2 quart of oil every 1000 miles or so due to my valve cover gaskets leaking. I was curious how difficult they are to replace and if it is better to go with a some sort of silicone gasket as opposed to the stock rubber one. Is there anything else that would be recommended I do while I have the top of the intake plenum off?
2000 4runner limited w/ e-locker and 4.30 gears 180k miles. OME 883/891, diff drop, 4innovations front steel bumper, cbi rear. Stock 265/70/16 cooper discovery h/t on 5 star limited wheels, new wheels and tires to come soon. Audio modifications: Sony HU, 10inch JL subwoofer w/ JL ported basswedge box and Rockford P300.1 amp.
4RUN0326 is offline   Reply With QuoteReply With Quote
Old 04-21-2013, 05:15 PM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I did mine two weeks ago. It' so nice to have a dry engine. You can do it your self.
I used the fel pro gasket kit for about $35 can be found on amazon.com. It included the spark plug tube gaskets. They needed to be replaced the old ones were brittle.
The key is to clean the gasket surface very good with brake cleaner or acetone. Use Toyota FIPG on the half moons and at the corners where the gasket goes over the cam.
Note, the plastic wire holder under the manifold will be very brittle, it will break and that's ok. Make sure to keep plastic bits out of the motor and tape it with electrical tape after you unplug the fuel injectors. Also, use a torque wrench when reassembling the manifold.
It just takes time to take everything apart and to clean up the cylinder head before reassembly. It took me two days but I went real slow. I could do it in one day next time.
you may also want to replace the PVC gasket. And of course it's a good time to clean the throttle body.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 04-21-2013, 05:54 PM #3
I have heard that the silicone gaskets can create better seals?? Anyways is it mandatory that the spark plug tube gaskets be replaced?
Old 04-21-2013, 05:54 PM #4
Almost forgot, what were the torque specs on the valve cover bolts and intake plenum?
Old 04-21-2013, 05:57 PM #5
downpour11's Avatar
downpour11 downpour11 is offline
Real Name: Rob
downpour11 will become famous soon enough
downpour11's Avatar
Real Name: Rob
Torque Specs.
Jon has a nice write up here: 3.4 Valve Cover Gasket Replacement (part#s n pics)
DOWNPOUR11's Build Thread
downpour11 is offline   Reply With QuoteReply With Quote
Old 04-22-2013, 02:11 PM #6
Diverse4runner's Avatar
Diverse4runner Diverse4runner is offline
Diverse4runner is on a distinguished road
I would check and see if the bolts are loose. Mine were about three turns loose. I tightened them back up and no more leaking. My moms Tacoma was the same way.
2015 4runner TrailP Super White
Stock
Diverse4runner is offline   Reply With QuoteReply With Quote
Old 04-22-2013, 02:32 PM #7
chuck norris chuck norris is offline
chuck norris is on a distinguished road
The VC bolts are spec'ed for 6nm (~5lb-ft).
In the meantime to stop your crazy oil loss, I'd snug down the VC bolts to 10nm and plan to replace your gaskets soon. I did the same thing to mine and it almost stopped the leak completely.
chuck norris is offline   Reply With QuoteReply With Quote
Valve cover gaskets SJC 3rd gen T4Rs 16 08-02-2012 12:29 AM
Valve Cover Gaskets DeeDub 3rd gen T4Rs 10 10-12-2010 12:53 PM
Which Valve cover gaskets? mitfan311 Maintenance/Detailing 0 11-15-2009 09:43 PM
DIY Valve Cover Gaskets MHartley Classic T4Rs 7 01-16-2009 04:56 AM
valve cover gaskets patgensel 4th Gen T4Rs 1 11-12-2006 08:40 PM
