04-25-2013, 08:25 PM
Evap Canister '02 sr5 3.4 v6
so i bought a nice new runner from a private seller, CLEAN RIDE. After the first month popped a CEL. Turned out to be the common p0446 for the Evap can. LAME! Turns out that he was probably topping off the tank, and since i didnt realize that was bad (until now) I was doing it also . I CHECKED CAR-PARTS.COM, ONLY 1 AVAILABLE FOR MY TRUCK! UGH!! cleared the code and it took 2 weeks, but its back. ANYONE KNOW WHERE I CAN GET AN EVAP CAN, besides the STEALORSHIP! My mechanic buddy cant even get a discount on it...HELP! Thanks Guys
04-26-2013, 12:38 AM
1996 Limited 4x4 Anthracite Metallic (162,XXX miles)
-OME 881/890 with Tundra Bilstein Struts/Bilstein 5100 rear, 16" 5-Stars with 265/75R16 Duratracs, Savage Sliders and Skids, B&M 70268 Trans Cooler, Amsoil Fluids
04-26-2013, 02:28 AM
I have a spare in the garage, thought it was the issue for my cel for awhile but turned out it was a hole in a vapor line. PM me and I'll give you a price.
2002 SR5 4Runner
Auto, 4x4, Camburg Long Travel, Relocated Dual Batteries, 34" KM2, Custom Armor
04-26-2013, 01:00 PM
Sorry new to T4R thread, what's PM? lol...
What's your price? How many miles is on it or DYK?
Thank you for replying
04-26-2013, 01:41 PM
It's either got 180k or zero, can't remember which one I put back on after I fixed my issue. Ill look when I get home later today.
2002 SR5 4Runner
04-26-2013, 11:42 PM
you might want to look into your gas cap before spending the $$$ on the more pricey parts. i got p0446 last month and also noticed there was no pressure in the system when i took the cap off to refuel. found my gas cap had a tiny crack in it. i replaced the cap and it fixed my problem.
02 4Runner 4WD 3.4 Sport Edition
ryhi's 4runner
99 4Runner 2WD 2.7 Base
ryhi's 4runner #2
04-27-2013, 12:32 AM
If the gas cap switch doesn't work, i found my leak by turning my air compressor regulator down to like 20-30psi and pumped it down the VSV line (think that is which one it is), found the leak in about 30 seconds.
Just unplugged it on the side that heads to the tank, has a green cap plug thing on the line for the actual toyota service unit. this is just above the wheel well on the driver front side. Then hooked this to it for a decent seal.
once the tank pressured up, i could hear the leak coming from it and plugged it up, no more code.
2002 SR5 4Runner
04-27-2013, 02:11 PM
Thanks for the answers. Definately checked the gas cap, screws on tight and no cracks, definitely pressure in the tank.
-dont really have the air compressor, but i have a buddy that may be able to help check for leaks.
Could it be possible that one of the Vsv's is bad? Or would it be best to just replace it all in a bundle if it is the canister.
Ive got a couple hundred bucks for a canister if its in good shape...been burned before so not looking to lose money.
THANKS
04-28-2013, 10:28 PM
Hey Broker, any way that you can take a better picture of where you are at in the engine bay and what line you are unhooking and putting pressure into?
I am DzastrousRunR's buddy with a 96 however the evap and vsv stuff is different on mine and his.
Have already checked the gas cap and it is good. I figured it is one of the VSV's or the evap can but if its possibly just a cracked line, that save him some green that he can then pay me to help him out (jk haha)
96 SR5 | Evergreen Pearl | E-Locker | 17" Tundra split 5 spoke wheels | 255/75/17 BFG KM Mud Terrains| Camburg 2.5 Coilovers | OME 890 & LC Tokico Black | Tundra 231mm Brakes | B&M 70264 Tranny Cooler | TRD catback exhaust | TRD 1st Gen (grey) Supercharger | Autometer boost and egt gauges | Curt Roof Rack | Pioneer Premier AVIC F90BT double din DVD/GPS/USB/SD running Windows CE 6 with custom firmware and user interface | JBL components | Kicker SX400.2 Amp |Kicker CVR 10" Sub.
05-15-2013, 07:04 PM
so I checked for the leaks in the lines, nothing that i could find or hear.
-also bought a new gas cap, definitely a better seal, but the CEL came back on in 3days AAARRRGGGG!!!
looks like il be replacing the evap and the valves. any good prices on a spare evap in good condition?
05-15-2013, 08:54 PM
Hey sorry I missed that last post asking about where to pressureize but I guess you figured something out. I still have my OEM evap can if you want to try it next. If you have a repair manual you should be able to check each valve to make sure they are functioning. Also in the manual it should give ways to check all the diphrams inside the evap canister.
2002 SR5 4Runner
05-16-2013, 05:34 PM
What kinda $ are you thinking?
you can PM me, I know how now...lol
05-16-2013, 07:19 PM
I have an 01 with the same code for about a year. I replaced the fuel cap but I still don't get the pressure release when I open the fuel cap. Is there a way to check the cap?
2001 4runner 3.4L Auto 4x4 --manual locking hubs-- Homemade winch bumper---Homemade roof rack---3"Toytec Coils---891 coils w/ ProComp shocks
Coming soon-- Rear bumper (don't know what kind yet)
05-16-2013, 10:46 PM
If you try my method above it will test against the cap as well.
2002 SR5 4Runner
05-17-2013, 12:52 AM
Real Name: Bill
Real Name: Bill
in texas it is part of the state inspection. go to someone that does inspections iam sure they would ck it for you...
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
