Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 04-28-2013, 02:34 AM #1
ellner357's Avatar
ellner357 ellner357 is offline
Member
ellner357 is on a distinguished road
Member
ellner357's Avatar
Front dif leak... uh oh
Well it looks like my front differential is leaking. On the side where the cv shaft goes directly into the pumpkin not the side with the shaft. It's leaking right where the shaft meets the pumpkin. Now is there a good online source for rebuild kits? Not that I know how to myself but help is an option. Or should I hunt for a wrecker dif? Also while I'm in there... locker options? I'd love your guys and gals input.
ellner357 is offline   Reply With QuoteReply With Quote
Old 04-28-2013, 02:56 AM #2
curtperry's Avatar
curtperry curtperry is offline
Member
curtperry is on a distinguished road
Member
curtperry's Avatar
The cv axle might not be sitting all the way in and therefore not sealing properly. Did you recently replace the axle?
__________________
'99 Limited, Millennium Silver, E-Locker
Front: '99 Tall Springs, Tundra Bilstein 5100's @ 5th perch, 3/8 in. Top plate spacer, Light Racing/SPC UCA's, 1.25in wheel spacers, sway end links from 2nd gen rear
Rear: Toytec Superflex, 05'+ Tacoma Bilstein 5100's, extended bump stops, extended brake line, e-brake strain relief bracket, 1.25in wheel spacers, front sway bar links, ES sway bushings
Other stuff: 1/2" body lift, B&M tranny cooler, extended rear diff breather, deckplate, blue-wire mod, ARB Tacoma BullBar, Smittybuilt XRC8 winch, 285/75/16's
curtperry is offline   Reply With QuoteReply With Quote
Old 04-28-2013, 03:24 AM #3
rideexileex's Avatar
rideexileex rideexileex is offline
Senior Member
rideexileex will become famous soon enough
Senior Member
Possibly just a torn/worn seal
__________________
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 04-28-2013, 12:08 PM #4
ellner357's Avatar
Member
Member
ellner357's Avatar
Quote:
No I didn't, haven't broken one of these guys yet. So the best thing to do is just pull the axel out and take a look or just replace the seal? Or do I need to pull the diff apart to do that?
Old 04-28-2013, 05:28 PM #5
curtperry's Avatar
Member
Member
curtperry's Avatar
Yeah it's probably just a worn out seal. Before doing a replacement I would visually check that each of the inner CV joint tulips are the same distance from the differential housing. They don't usually pull out on their own but stranger things have happened.
For the seal - drain the fluid, pull the CV axle, pull the old seal, and push in the new one.
__________________
Old 04-28-2013, 06:31 PM #6
ellner357's Avatar
Member
Member
ellner357's Avatar
Hmmm well I'll get in there and have a new seal on hand when I've got the truck up doing the balljoints and steering rack thanks for giving me a great idea what kind of trouble I'm getting into
Old 04-28-2013, 10:09 PM #7
Senior Member
Senior Member
You shouldn't have to drain the fluid - if you jack the one side of the truck up high enough, gravity will hold most of the fluid in and you shouldn't lose any/much. I just replaced my own and found that the plastic lid from a peanut jar worked great for tapping in the new seal. Others suggested a small Campbell's soup can works too
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Front Axle Seal Leak phillyd2 5th gen T4Rs 15 07-31-2017 10:02 PM
Front passenger CV diff leak ? Mr. B 3rd gen T4Rs 6 02-26-2013 06:27 PM
Front CV seal leak help.. maxspeed96ct 3rd gen T4Rs 5 08-31-2011 12:21 PM
cant get front diff (CV) oil seal to not leak...pls help on this cordrayj1 3rd gen T4Rs 7 08-18-2011 08:43 AM
daystar 2.5 front & CV grease leak soundstudio315 Off-Roading 8 06-03-2009 12:23 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2026, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
Copyright © 2020
