05-07-2013, 08:42 PM
Painting Coils vs. Powder Coating
I know powder coating is ideal, but has anyone ever painted their coils? If so, what kind prep/paint did you use and how is it holding up to the abuse?
2014 5th Gen for work.
2000 3rd Gen for fun!
~ 3" Toytec Lift, LC 8 Wraps, 285/70/17 AT, Sequoia Rims Split Spoke/Plasti Dipped, Spydertrax 1.25 Spacers, Tundra 231mm Brake Upgrade, Deck Plate Mod, Sport Hood Swap, 2002 Tail Light Swap, Yakima Load Warrior/Snowboard Racks
My 2000 Build http://www.toyota-4runner.org/3rd-ge...ld-thread.html
05-07-2013, 09:24 PM
Real Name: Instagram: briansd_97r
Well most peoples coils are covered in mud and dirt 24x7. I don't think altering the color is very common.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
05-07-2013, 10:40 PM
I know but I may be putting on a set that has a little bit of rust, so if I can strip & paint them w/o chipping, I'd like to do so.
I'd like to keep my truck as clean as possible.
05-07-2013, 11:00 PM
Real Name: Isaac
Real Name: Isaac
just paint them, the powder coating will wear off in the same places that the paint will so dont waste your money on the PC job. just clean them really good with some soap and water, sand and scuff any bare areas or areas with chips or nicks ect, then use a good self etching primer and give it a few light coats (as instructed on the can) to give good full coverage then let that set up, lightly scuff that and spray with desired color epoxy paint, that will be your best bet against road spray and debris.
-i use epoxy paint on all my frames and metal under the truck, like axles ect. typically i get under my truck once a year in the late summer and spray all exposed metal that has been scrapped or bashed on rocks, giving it a good seal for winter, that way i keep any major rust issues from ever happening. i have never had a vehicle that has rusted out on me, and i lived on the coast for a few years and was driving my old 85 truck back then. its frame and everything under the truck looked better than the rest of the truck, and is even in better condition than the 85 truck i have now that has been in eastern oregon(high desert) 90% of its life. epoxy paint is tough as far as rattle can paint goes and its dirt cheap compared to PCing
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
05-07-2013, 11:06 PM
Thanks for the info kid!
Just the info I was looking for.
Did you need to put a clear coat on anything?
05-07-2013, 11:12 PM
Real Name: Isaac
Real Name: Isaac
do you plan on taking this thing to a car show or something? lol naw man again dont waste your time or money, i mean you can if you want to be overly redundant but if you want them to be shiny just buy the gloss black(or what ever color you chose) epoxy paint. -its what i used on my 2" receiver on my runner, though i used semi gloss black, and i would swear its gloss black, but its looks good when the truck is clean, maybe a little too good
05-07-2013, 11:20 PM
No, but I'm not a painting expert, so I thought it would just be an added layer of protection.
Thanks for your help!
05-07-2013, 11:44 PM
Real Name: Evan
Real Name: Evan
I painted a rusty set (from a northern runner) of front 99 talls a while back. Never again! I had to grind down some of the rusty areas, then etching primer, then I used VHT Chassis epoxy paint. The winds on the coils make it such a ***** to get good coverage. Rear coils are spaced much further apart, so not nearly as tedious.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
05-08-2013, 12:11 AM
if you rattle can it use this stuff, ive used it on my factory skid plates and it holds up well.
05-08-2013, 12:14 AM
Real Name: Evan
Real Name: Evan
^^^^ That's the one I used
05-08-2013, 12:28 AM
i even used it on the intercooler pipes of my trans am
