Old 05-12-2013, 11:53 PM #1
kmiller93's Avatar
kmiller93 kmiller93 is offline
Real Name: Kyle
kmiller93 is on a distinguished road
kmiller93's Avatar
Real Name: Kyle
Question on Rear Drum Grinding Noise
Persistent short grinding noise from left drum brake not constant but in intervals. I drove home and by the time I got there the grinding noise went away. I compared the temps on the drums and the Left one that was making the noise was much hotter then the Right. I could keep my hand on the right one but the left was too hot to touch. Any ideas on why it was doing this? I guess somethings stuck in there and not releasing the shoe. The noise is quick so it doesn't sound like the whole shoe is pressing against the drum. Should I just try to try and clean them before I have them checked by a mechanic?
89 S13 240sx IG SR_Hatch
01 T4R Sport 4wd
http://www.toyota-4runner.org/3rd-ge...ead-2-0-a.html
kmiller93 is offline   Reply With QuoteReply With Quote
Old 05-13-2013, 12:10 AM #2
t4r4life's Avatar
t4r4life t4r4life is offline
Real Name: Eric
t4r4life will become famous soon enough
t4r4life's Avatar
Real Name: Eric
Take it apart, make sure all springs are set right and didnt fall off.
http://www.toyota-4runner.org/image.php?type=sigpic&userid=47554&dateline=138992  2355
t4r4life is offline   Reply With QuoteReply With Quote
Old 05-13-2013, 12:33 AM #3
mikebontoft's Avatar
mikebontoft mikebontoft is offline
mikebontoft is on a distinguished road
take it apart, look for any obvious signs of excessive wear or broken parts, and lubricate the backing plate where the side of the shoes contact it. Maybe a shoe is getting caught on the backing plate and just rubbing the drum.
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious View Post
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
mikebontoft is offline   Reply With QuoteReply With Quote
Old 05-13-2013, 08:43 AM #4
jreask's Avatar
jreask jreask is offline
jreask is on a distinguished road
jreask's Avatar
Make sure you don't have a leaky axle seal. Just a small amount of gear oil will cause the shoe to stick to the drum intermittently. Ask me how I know.
jreask is offline   Reply With QuoteReply With Quote
Old 05-13-2013, 06:54 PM #5
kmiller93's Avatar
Real Name: Kyle
kmiller93's Avatar
Real Name: Kyle
Im really hoping its not an axle leak.
01 T4R Sport 4wd
Old 05-13-2013, 08:36 PM #6
blueblur1984's Avatar
blueblur1984 blueblur1984 is offline
blueblur1984 is on a distinguished road
I hate to be the bearer of bad news but I had the same problem...I thought it was just that the rear brakes needed new shoes. I took it to a shop last week and it turned out to be the axle seal leaking fluid into the brakes and gunking it up. It was about a $450 fix or if you have access to a cheap machine shop you can probably do it yourself cheaper.
blueblur1984 is offline   Reply With QuoteReply With Quote
Old 05-15-2013, 11:29 PM #7
kmiller93's Avatar
Real Name: Kyle
kmiller93's Avatar
Real Name: Kyle
My rear drums were full of dust. When I had my truck in to get the UCAs and stuff the mechanic tightened the rear brakes, when he did it there was no dust. I think he did it too much so they ground down and made a lot of dust. Idk though just an idea.
01 T4R Sport 4wd
Old 05-15-2013, 11:31 PM #8
kmiller93's Avatar
Real Name: Kyle
kmiller93's Avatar
Real Name: Kyle
Ya if the problem comes back it may be that. I just dont have any leaks on the axles as far as i can see.
01 T4R Sport 4wd
Old 05-16-2013, 04:28 PM #9
Well that may not be an axle shaft seal then. With mine it was pretty obviously gunked up. Best of luck and keep us posted.
3rd gen , brake , drum , drum brakes , drum repair
grinding noise mharris 3rd gen T4Rs 8 07-29-2017 10:41 PM
Grinding Noise gizmopt2002 Maintenance/Detailing 2 09-10-2006 03:23 PM
Grinding noise when put in 4Lo N8G 4th Gen T4Rs 7 11-19-2005 07:32 PM
grinding noise coming from rear end sloopy 3rd gen T4Rs 15 11-07-2005 12:56 PM
