Old 05-19-2013, 09:23 PM #1
jreask's Avatar
jreask jreask is offline
jreask is on a distinguished road
jreask's Avatar
Compression test results
I did the compression test today on my 99 V6. I followed the steps in the FSM. This Runner has just over 150K on it. All cylinders were within 5 PSI of each other. Five of them showed 210 PSI and one showed 205. The FSM calls for pressure above 174 PSI. My question is if the higher pressure is anything to worry about? I was using an inexpensive rental from O'Reilly's that was brand new and was never opened. Thoughts?
JR
jreask is offline   Reply With QuoteReply With Quote
Old 05-19-2013, 10:03 PM #2
koulee koulee is offline
Banned
koulee is on a distinguished road
Banned
Run Seafoam thru there to clean up carbon deposits then retest to get a truer number.
koulee is offline   Reply With QuoteReply With Quote
Old 05-19-2013, 10:42 PM #3
98OzarksRunner's Avatar
98OzarksRunner 98OzarksRunner is offline
98OzarksRunner is on a distinguished road
Numbers look good.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)
In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
98OzarksRunner is offline   Reply With QuoteReply With Quote
Old 05-19-2013, 11:31 PM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Nice numbers. I checked mine via this:
Compression test...
Any pics of the leak?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 05-19-2013, 11:45 PM #5
jreask's Avatar
jreask's Avatar
Compression test...
Shoot, I forgot to take any pics. I took the upper and lower halves apart and there was oil caked on the top of the lower half like it had been oozing out of the metal gasket. It was definitely coming from the aluminum intake though. I assume it had been slowly leaking for a long time. The metal gasket was slightly wet with oil. I didn't have a new gasket so I just tightened it back up and I'll keep an eye on it. I think the PCV valve had to be the culprit. How else would that much oil be seeping through the gasket?
Old 05-20-2013, 02:09 AM #6
nissanh nissanh is offline
Different pressure testers give different numbers. Use a snap on compression tester for better results
compression test done, don't know about the results delgadog Classic T4Rs 9 02-22-2013 07:34 PM
Compression test... LittleCaesar 3rd gen T4Rs 9 06-11-2011 02:05 AM
Test Results BobLMTDT4R 3rd gen T4Rs 15 04-14-2010 12:59 AM
Crash Test Results defrogme 5th gen T4Rs 11 02-04-2010 12:15 AM
Basic Compression/Leak Test Diagnostics hankrearden Classic T4Rs 0 11-10-2009 01:58 PM
