Originally Posted by 98OzarksRunner
It's not all that unusual. The actual release/catch is on the bottom of the door and the handle pulls it with a cable (so spraying the key lock doesn't do any good). What usually happens is the release/catch on the bottom of the door gets gummed up. Remove the inner door panel to open the latch by hand. Then spray it full of WD40 until it runs clean. That should fix the latch part. The electric/key lock is probably another story. On my 98 I could unlock it from inside but not with the key, so I just used the inside switch.
Thanks, I'm gonna have to give this a shot later in the week when I have time.
Hopefully this works!
