11-29-2006, 02:23 PM
265/75/16 fit without a lift?
guys, i know this has been beaten to death, but im looking to get new tires in a size slightly larger then the stock 265-70-16 in running now. I have spent the past 45 minutes trying to search, but im not sure if the search feature is working cuz nothing comes up. Anyone got pics of their stock height 4Runner with a 265-75-16? Thanks.
11-29-2006, 02:39 PM
I don't have 16's, but my 265/70/17's are essentially the same height. Here is a pic. I'm pretty much 100% stock.
Stock 265/65 compared to 265/70
I know of several people running 265/75/16's with no issues.
11-29-2006, 02:43 PM
Thanks for the pics, looks good. I was afraid of it being to big and rubbing.
12-01-2006, 05:21 PM
Real Name: Weston
Real Name: Weston
I'm running 265/75 16s no problemo.
The New - 2019 TRD ORP, Supercharged, Lifted, 285s, armored,
https://www.toyota-4runner.org/5th-g...9-trd-orp.html
The Old - 2000 SR5, Supercharged, E-locker, 35s, 4.88
www.outworldhq.com/2000-toyota-4runner
12-01-2006, 07:17 PM
Real Name: Chris
Real Name: Chris
265/75/r16... No lift... No Problem...
1996 Toyota 4Runner "UnLimited"
12-02-2006, 02:12 PM
Super Moderator
Super Moderator
Being you have the shorter sitting '01 it'll be a little tighter than previous years but will still fit fine.
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
12-10-2010, 12:20 PM
05-15-2011, 03:23 PM
Figured I'd add to this thread rather than start another.
I'm pretty sure I already know the answer from looking around the forums but I just want to make sure. Plus I'm seriously busy today so can't research as much as I'd like.
I'm looking at picking up a set of Goodyear Wrangler Duratrac's for a good deal that I'd like to jump on. Sized6 265/75/16
My question is, will 265/75/16's fit on a stock 5 star rim and not rub on my 1999 limited 4wd, not lifted?
I'm pretty sure they won't from what I've read, just want to be sure before I drop the $$$$.
Thanks in advance!!
05-15-2011, 03:39 PM
Little to no rubbing. Go for them!
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
05-15-2011, 08:35 PM
Originally Posted by 4RunnerGirl01
I have been researching a lot about tires. Using this site for most of my questions.
I was scared to see if this size would fit on my 01, being they are lower than previous years.
Well they are perfect. LT265/75/16 Nitto Terra Grapplers. no rubbing at all, full lock turns, bumps. also, my parents have a really steep entrance at their house, with flex, no rubbing.
No lift, 123K, stock suspension. These tires are great. Not rough at all being a LT either. incredibly smooth also.
here are some quick shots.
Beautiful. I can't wait to get my new Destinations on this week in that size.
2001 SR5 4X4, V6, 3.4L
05-15-2011, 08:51 PM
Real Name: Addison
Real Name: Addison
Here are pics of mine. No lift - 265/75/16 BFG KM2's.
They rubbed up front when I first put them on. (due to the 4.5" BS of the LC80 wheels) but after some massaging of the pinch weld, they are clearing ok. I am sure they will rub a little when wheeling though... so it depends on what wheels you will be running. The factory wheel are tucked in the wells better with the higher backspacing and will rub less at stock height.
4Runner2 by Headlight Hookup, on Flickr
4Runner1 by Headlight Hookup, on Flickr
4Runner3 by Headlight Hookup, on Flickr
05-16-2011, 09:03 AM
Sweet. I'm doing factory wheels. Feel like getting the running boards off right away now, too. I've got 255/70/16 Grabber AT2's on there now (not sure why the previous owner got that size) and they are getting close to the end, so they are lacking tread height. Combined with the boards it looks too much like a station wagon.
I want to take the flares off, too, but I'm not sure how the paint will be. We'll see. Already have to do a bit of touching up on the lower body behind the board plastic.
I want to do a 1" lift for aesthetics, and I assume that would eliminate any rubbing, even if there were a slight bit. Just figuring out the cheapest and most stable (zero negative effect on mechanics) way to do this.
06-01-2011, 09:48 PM
OK, I got my new 265/75/16 Firestone Destination ATs on, and they look fantastic. I've fallen in love with the Runner yet again. Basically I went up two sizes since the previous owner put 255/70/16s on for some reason. Plus the height of having new tread.
The truck drives so much smoother and softer as well.
I couldn't resist and had to take the running boards off right away (not so easy with rusted bolts) and put some new mudflaps behind the front wheels as well. Wow, wow. I can't help staring at it out the window all the time. Pics to follow.
02-21-2012, 08:38 PM
Do you guys find big trucks (F-250s, Chev 2500s) with stock tires look really fruity after your eyes get used to looking at our Runners with over-sized tires?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
