11-18-2019, 10:45 PM
#61
Real Name: Robert');DROP TABLE Students;
Mine showed up in the mail about an hour before I had to leave for the airport.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
11-18-2019, 11:25 PM
#62
Plenty of time for a sicmod!
11-24-2019, 07:53 PM
#63
I know this is posted in the 3rd Gen section, but as a heads up, the 4th Gens have the hose barb pointing straight down, and not at a 90 degree angle. So while they will fit, they really aren't plug and play as it puts a nice kink in both the hoses.
Will have to continue searching for a suitable replacement.
11-24-2019, 08:00 PM
#64
Did this Sicmod™ in about 10 minutes this morning, so you were right. And it really is an improvement.
11-25-2019, 10:38 AM
#66
Got mine replaced this weekend. A lot easier than I thought. I used a small flat head screwdriver to press in the clips 1 at a time. I tried using small pliers to press both clips at the same time but couldn't get the pliers to fit. Much better spray pattern.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
11-25-2019, 11:54 AM
#67
I installed the Odyssey sprayers on Saturday. What an improvement! I adjusted the nozzle as high as it would go and it's perfect.
Originally Posted by fourfive
I used a small flat head screwdriver to press in the clips 1 at a time. I tried using small pliers to press both clips at the same time but could get the pliers to fit. Much better spray pattern.
I tried pliers at first with no luck. I did the same as you, one side at a time, but using a plastic trim removal tool with a flat blade.
1997 4Runner SR5
3.4L/5 Speed
265/75/16 Cooper Discoverer AT3
11-25-2019, 03:17 PM
#68
Ordered a set. I feel dirty putting Honda parts on my Toyota....
11-25-2019, 04:12 PM
#69
I'll echo the thanks for the research and write-up! Ordered a set as well! Just happened upon this thread while looking for something else, and it was an opportune time since one of the nozzles on the right side just ceased working.
I'd be interested as well to hear what kind of options we have for the rear nozzle. I did the rear wiper mod and the wiper does not make good contact with the window, so I'll be going back to stock, but also would like to swap out the sprayer as well if possible.
11-25-2019, 04:23 PM
#70
Real Name: Patrick
Real Name: Patrick
What is the "rear wiper mod" you're talking about?
11-25-2019, 06:48 PM
#72
Real Name: Patrick
Real Name: Patrick
Thanks! I've never heard of that before
11-05-2021, 04:51 PM
#73
Well I drank the kool-aid, and these sprayers are great!
Thanks for the pics. Older thread but looking to do this ...are you still happy with this mod? Do the Odyssey nozzles cover the same footprint of the Toyota ones?
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
11-05-2021, 05:01 PM
#74
Yes, the Honda nozzles are 100% badass and a very worthy sicmod.
11-05-2021, 05:03 PM
#75
Real Name: Tony (no surprise)
Was just thinking of this discussion as I used my wipers and spray nozzles after some recent CA rains (rarity here), and was pleasantly reminded of how well they work.
2000 Limited, E-locker
Maintenance/Build Thread
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
HVLP Spray Kit
bofa |
For Sale: Non-T4R Items |
0 |
10-24-2012 11:14 AM |
Washer Nozzles
the_dingman |
Classic T4Rs |
4 |
12-05-2009 12:24 AM |
Spray on mud
Sac State |
Off Topic |
4 |
07-23-2005 02:05 AM |
Help!! Bug spray
jake0713 |
Maintenance/Detailing |
1 |
09-13-2004 10:55 PM |
