06-20-2013, 01:46 PM
Bought a 2000 last Sunday, was great, but now have check engine light/power loss
So, after a long search, I found my 4runner and bought it from a private party just this last Sunday morning. The chassis has 171,000, and cylinder work and a ton of new parts (radiator, timing, water pump, fuel pump, comprehensive tune-up, etc.)
Had a mechanic from work spot check it, and he also hooked up a scanner before buying it, and it showed no problems, errors, etc.
Wound up paying $4000 for it, and all seemed well mechanically over the last week, and I was absolutely pleased about the car, as it's just clean throughout.
So last night I was running low on fuel (gas light came on), got 1/4 tank of mid-grade fuel at a Chevron, drove 3 miles home, and all seemed fine.
This morning, I get in the car, and the check engine light stays solid, and it seems like a bit of a power loss. Merge onto the freeway, and I practically have to floor it to get up to 60 mph. Eventually the power seems to return, but it is clearly running a bit slower and the CEL is staying solid. Idle seems ok, and car isn't shaking or smoking, and is holding fluids OK. The oil seemed a little low, about 1/8 inch below full.
I'll be getting the error codes on my lunch hour in a bit, but can anybody here offer some insights? Is it a sign of impending doom here? Thanks for any help!
06-20-2013, 02:05 PM
Sounds like a possible p0171. At this point it could be a couple different things (plugs, wires, maf sensor, o2 sensors, vacuum leak) just wait until you get the code/s and trouble shoot from there.
06-20-2013, 02:08 PM
Real Name: Jeff
Real Name: Jeff
Are you sure you put the fuel cap back on , or on properly ?
1998 4Runner 4WD Ltd
06-20-2013, 02:10 PM
Po420, plugged kitty. But get the code first.
I checked it this morning, and it was on there tight. Pulled it off and put back on to be sure, started back up, and the CEL is still on.
06-20-2013, 02:13 PM
Second that, w/o checking the codes you are left to "spitball" it....If it is not possible to read the codes, I'd pull the MAF and clean it out, going from there
06-20-2013, 02:14 PM
Real Name: Jeff
Real Name: Jeff
Ok . Dont you have to clear the code first though ?
I had the same thing happen and the cap actually needed replacing . But I needed to clear the CEL as well .
Funny as mine was right after purchase too
06-20-2013, 02:16 PM
Fuel cap loose may cause the evap leak, but not the power loss....fouled plugs or wire problems usually cause intermittent issues, stumbling and so forth...The MAF would cause a consistent misreading of the Air intake leading to a consistent power loss. A fuel supply issue could also cause a consistent low of power....pulling the code would be very revealing...
06-20-2013, 02:22 PM
thanks for the replies everyone...i'll post the codes as soon as I get them. the guy i bought the car from claims he'll scan it and fix what the problem is - "if it's a quick fix" (great) i see a catalytic converter replacement for this thing is like $600 just for the part....I know you should expect stuff to go wrong with an old used car, but I thought I'd get at least 1 week of driving out of it before having to throw down that kind of money, good god.
06-20-2013, 02:50 PM
It happens! very cool of the seller to offer that. The one I bought developed a issue on the way home from Texas to Cape Cod.
Hope it all works out
06-20-2013, 02:54 PM
If it does need a cat, look online for one of the CARB approved cheap replacements. You can order them from Napa, Oreily, etc and have a local muffler place install. just my .02
Good luck
98 4runner. L.A.M.B. (locked, armored, methanol injected & blown) URD 7th & 2.2 pulley, meth injection, ARB bumper & lockers, Warn 9.5xp winch, yukon 4.88 gears, rear disk conv, blah,blah, blah blah [B]SOLDB]
93 Hilux Surf, 3.0 kz-te, restoration in 3, 2, 1
06-20-2013, 02:59 PM
Good luck
Thanks for the tip - think I jumped the gun on the Cat replacement - it looks like the one I saw online for $550 isn't even legal in California...but now I'm wondering if there are 2 Cats on this thing I have to worry about?
06-20-2013, 03:25 PM
If originally sold in Cali, based on the year yes I believe 2.
06-20-2013, 03:27 PM
I wouldn't order anything until you pull codes. It might just be a dirty MAF, a free 10 minute fix.
06-20-2013, 04:17 PM
Error is P0402...seller claims not a big deal? says something with a valve
