I'm not having much luck getting help at yotatech, so I thought I'd come over here and see if y'all could give me some advice about my 1999 4Runner (ABS, 4x4). I'll try and be succint, but I've been working on this for a while.
Briefly, I started with two problems: (1) a hard pedal and weak braking and (2) bellcranks were frozen with corrosion. I removed the bellcranks, refurbished and painted them, and reinstalled with a new set of shoes (old shoes were unevenly worn, with one down to 1/64"). I inspected all the connections, replaced the vacuum line to the booster, and bled the brakes.
So, still chasing the weak braking, I tested the booster according to the FSM. Results of each test are listed below, but long story short, I decided to replace the brake booster.
I replaced the booster and bench bled and reinstalled the original master cylinder.
Current Problem: The brakes came back super strong and responsive, but when I test drove it around the block, the brakes increasingly started to drag. I parked it a few minutes, then tried to do another test drive; the brakes were engaged so hard, I could barely get it to move.
Thinking I'd over adjusted the rear brakes, I popped them off and adjusted them so loose that the parking brake didn't engage. Then I backed-and-forthed in the driveway while cranking on the parking brake to hopefully adjust them right. I test drove it again and the brakes started dragging increasingly hard, enough I barely made it back home. The front brakes were warm and the rears were cool.
So this went on until 11:30 pm, and I'm now discouraged and exhausted (upper 90s here today). I could use some expert advice and I'm hoping y'all can help me figure out what to do next.
BELOW is a bunch of stuff I've already done/checked, which you might find useful to know.
Results from the FSM brake booster tests:
1. OPERATING CHECK
(a) Depress the brake pedal several times with the engine
off and check that there is no change in the pedal
reserve distance.
- No change in reserve distance apparent. Whooshing sound on first pedal press with engine off.
(b) Depress the brake pedal and start the engine. If the
pedal goes down slightly, operation is normal.
- Pedal goes down slightly.
2. AIR TIGHTNESS CHECK
(a) Start the engine and stop it after 1 or 2 minutes.
Depress the brake pedal several times slowly.
If the pedal goes down farthest the 1st time, but
gradually rises after the 2nd or 3rd time, the booster is
air tight.
- Goes down easy the first time, then presents resistance on subsequent pushes and travels shorter distance.
(b) Depress the brake pedal while the engine is running,
and stop the engine with the pedal depressed. If there
is no change in the pedal reserve travel after holding
the pedal for 30 seconds, the booster is air tight.
- When I turn off the 4runner, the pedal immediately pushes up against my foot and wants to rise up.
Things I checked:
- Brake fluid was at correct level and was flushed with Valvoline DOT 3 & 4 synthetic fluid 15 months ago. I re-flushed the system with a motive bleeder, same fluid. The old fluid was a slightly darker than new but wasn't very bad.
- Checked brake lines for obvious leaks - none found. Flexible lines are nearing the point they need replacing.
- Parking brake was non-functional and parking brake bellcranks were both frozen. I refurbished and replaced bellcranks.
- Old booster had a good check valve and vacuum is going to the booster.
- I measured the clearance between the booster push rod and the master cylinder using a vernier caliper and adjusted them to be as close to 0 as I could.
- I bench bled the master cylinder, holding my fingers against the line ports and pushing the piston with a punch. I bled the rest of the system with a motive bleeder after reinstalling the booster.
- The new booster install was fine, but I worried about doing damage while cramming the booster into place. The linkage between the booster and the brake pedal was very tight. I'd previously adjusted the brake pedal travel distance according to the FSM.
