Originally Posted by ellner357
Ok so I'm doing my upper and lower ball joints. They're all buttoned up and torqued on. I got a daystar lift kit (don't judge it was cheap and temporary lol) 1.5 front 2.5 back and some bilstien 5125 for the back.
My problem is now that I have the 1.5 installed in the front at full drop my spindle is rubbing my spring. Wtf! There's no adjustment on my uca so how can I fix this. I can't be the first to have this issue. I'm back to work tomorrow on it. It also looks like the spring is located in the strut so I can't turn it.
I just installed a pair of Icon 2.5 remote reservoirs on my 2000. These came with two spacers in the bottom bolt mount position.
One of the spacers is about 1/8" wide and the other about 3/4" wide and they are supposed to be installed with the wider spacer in the rear which pushes the coilover closer to the front of the lower control arm. Instructions say this is for clearance issues.
Not sure if this would apply to yours but if you have replaceable spacers on the bottom it may be a lot simpler solution?
Gary
