Originally Posted by Rangeroad
Anybody?? I gotta figure this one out
p0770 has to do with torque convertor lock up. Replacing the solenoid (solenoid "E") usually fixes the problem. But if it doesn't either your valve body is really messed up or you have an electrical issue. I also read somewhere before that sometimes you have to replace the torque converter to fix the issue.
A flush might fix the issue, but usually once you have a transmission issue a flush is just a band-aid. IMO.
