Old 07-02-2013, 12:18 AM #1
thebrandon's Avatar
thebrandon thebrandon is offline
thebrandon is on a distinguished road
thebrandon's Avatar
Steering Rack and Power Steering Pump Replacement
Tomorrow I am going to have the privilege of replacing the steering rack and power steering pump on my 2000 4x4 SR5. I have replaced PS pumps before, replacement rack boots, and tie rod ends, but never the whole steering rack. It seems to be pretty straight forward, and I have the replacement rack and PS pump. Are there any tricks I should be aware of, or any tips anyone can provide? Or is it pretty much, unbolt everything and slap it back together? I'll try to remember to take pictures along the way for you guys too.
Also for those wondering why I might be doing this. I just recently acquired a bad leak in the steering rack. The power steering failed. I wasn't driving when the failure happened, so I don't know how stressed the pump was when the failure happened, or if it made any noises it shouldn't have been making. There still seems to be fluid in the res, so that is somewhat of a good sign. Rather than taking the risk of leaving metal shavings in the system, I figured I would just swap both out at the advice of my friend who is a Toyota tech at the local dealership.
thebrandon is offline   Reply With QuoteReply With Quote
Old 07-02-2013, 12:46 AM #2
nissanh nissanh is offline
Use a GOOD QUALITY TOOL (size: 17 mm?) to lose the high pressure line going to the steering rack. This is the toughest thing you will encounter.
It is hard to use force to turn the tool in that small area. I used a pry bar to give a push to the tool. If you have trouble, lower the steering rack with the high pressure hose (disconnect at the power steering pump)
Old 07-02-2013, 01:09 AM #3
4Running Daily's Avatar
4Running Daily 4Running Daily is offline
Real Name: Connor
4Running Daily will become famous soon enough
Real Name: Connor
The pump replacement is actually very easy to do. I wouldn't worry about that too much. One large bolt, possibly 17mm like nissanh said, not too bad with a huge cheater bar.
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner View Post
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
4Running Daily is offline   Reply With QuoteReply With Quote
Old 07-02-2013, 09:46 AM #4
nobb nobb is offline
nobb is on a distinguished road
The hardest part is probably the power steering rack. A HUGE PITA to get those high pressure lines off. There simply is no room, and sometimes it's seized on.
If you manage to get it off, please let us know how you did it!
nobb is offline   Reply With QuoteReply With Quote
Old 07-02-2013, 10:04 AM #5
MountainMike11 MountainMike11 is offline
MountainMike11 is on a distinguished road
if you are going to take it all apart I would disconnect the high pressure lines from the pump down and pull them out a little bit before you disconnect them at the rack.
otherwise it's tight, real tight. soak them with blaster and hope you dont strip them in the tight area. if you can get a adjustable wrench in there to break the initial seal then an open ended wrench can work.
I had a hard time getting the flare wrench at the right angle to even make it useful to work. if you don't have one and plan on buying one, I recommend the ones with adjustable heads so you have more angles to work with. they are more expensive but would be worth it on this job.
the top middle bolt is also kind of difficult to get out and can't really use a socket on it very well. you can loosen it with one, but then it gets progressively tighter as you unbolt.
MountainMike11 is offline   Reply With QuoteReply With Quote
Old 07-02-2013, 10:07 AM #6
^Good suggestions.
One of the pressure lines (return) is just a simple hose that can be unclamped. With the feed line, I couldnt really see how you disconnect the end from the pump. There isnt exactly a fitting. It appears to just be a thicker grade hose permanently clamped onto the pump. Thoughts?
Replacement power steering rack bushings DerJaeger 3rd gen T4Rs 124 01-29-2022 12:13 AM
Power Steering Pump HELP!!! kpnavarro Classic T4Rs 13 11-09-2012 05:37 PM
Metal in Power Steering Fluid AFTER Pump Replacement gargan333 Maintenance/Detailing 2 03-09-2011 10:20 AM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
power steering pump replacement jlfindley74 Classic T4Rs 0 12-28-2008 04:06 PM
