Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 07-22-2021, 08:51 AM #4006
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold
Real Name: Patrick
Originally Posted by gamefreakgc View Post
I don't know of any torque spec for that nut. My general rule of thumb for these unknown nuts and bolts are:
14mm = Strong arm it
12mm = Firm and snug
10mm = Slightly more than finger tight
Has yet to let me down.
A fellow kindred spirit
2000 Limited V6 Auto E-Locker
Old 07-22-2021, 02:21 PM #4007
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold
Real Name: Jerod
Oh, my bad!
I get my metric nuts and bolts from Home Depot or Ace Hardware. HD has a separate drawer on the end that has all their metric nuts and bolts. If I can't find it there, Ace Hardware always has it but for 2x the price.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 233K miles.
326WHP 347TQ
Old 07-24-2021, 07:40 PM #4008
nhenscheid nhenscheid is offline
nhenscheid is on a distinguished road
Originally Posted by nhenscheid View Post
Sorry, I meant spec as in what size & type of nut to get to replace it with, not torque spec. It just seems like an odd/special size so I thought I'd see if anyone knew a source for it.
FYI for anyone who happens across this in the future - it's an M8x1.25 nut, but it needs to be a 10mm wrench size (width across the flats) in order to fit in the little recess. I couldn't find such a nut so I made one by taking an M6 nut (10mm across the flats), drilling and tapping it out to M8x1.25. Helps a lot if you have a metal lathe but just a vice and a steady hand should work too.
nhenscheid is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 07:45 PM #4009
OK wizards, here's my next challenge. I thought it would be a good idea to swap out the gaskets in my bypass valve assembly - there are supposed to be two of them, one where the pipe meets the rotor housing, and one where the pipe meets the butterfly valve housing. My problem is, I can't get the pipe separated from the butterfly housing - the retaining clip broke and now it's stuck on there:
Any bright ideas for getting that thing off there without completely destroying it? Anyone have a source for buying a new bypass assembly (not the valve but the butterfly assembly & pipe)?
I'll probably just get it put back together as-is (leaving this mess as-is) but eventually I fear the gasket that I can't get at will lead to a vacuum leak, so eventually it'll need to get swapped.
Supercharger decals w/ no Supercharger(poser?) LuvmyRunner1980 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-20-2013 05:13 PM
WTB: TRD SUPERCHARGER 3.4 96-up ramminyota Want to Buy/Trade 2 03-12-2010 02:45 PM
trd supercharger riceandpho 4th Gen T4Rs 4 09-23-2009 06:52 PM
4th gen Supercharger Paulmessen Engines / Suspension / Wheels / Tires / Audio / Accessories 10 07-05-2006 07:21 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
