Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 04-12-2024, 02:30 PM #4231
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
The 3.4L TRD Supercharger Thread
Charger is on. Just have to finish the timing belt.
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 04-22-2024, 03:31 PM #4232
05SVRACER's Avatar
05SVRACER 05SVRACER is offline
05SVRACER is on a distinguished road
05SVRACER's Avatar
I've been fighting a problem for a while and want to see if you guys have any input.
My 98 3.4 SC manual falls on it's face and pulls all timing until around 3500 rpm, then it pulls "ok". I do have the URD / split second FTC piggyback.
I thought I was having a knock sensor issue, which I have the GM style external bolted to the head setup and have had that on the truck since shortly after the rebuild and SC install roughly 50k ago. Have installed new sensors, remotely put them in the glovebox covered in foam, and disconnected them. Disconnected resulted in a CEL and pulling all the timing completely.
With all that being said, It's looking like the factory ecu or the piggyback. Has anyone had a similar problem? Any way to test either or send either off for testing / repair?
I'm strongly considering a stadalone ecu, but don't know where to start...
98 SR5 4WD 5spd: Project awesome commencing 6/21
11 Ducati Multistrada 1200 ST
10 Husqvarna WR300
06 KTM 560 SMR
99 Gas Gas 270 TXT
05SVRACER is offline   Reply With QuoteReply With Quote
Old 04-24-2024, 05:33 PM #4233
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
There's nothing magical about 3500 RPM but it could be an open loop/closed loop dynamic. If you are really mashing it, it will downshift to about 3500 RPM and switch to open loop in which the piggyback alters the signals to add more fuel and pull some timing. That makes me think it's not the piggyback and instead you've got a rogue sensor feeding bad data in closed loop. The sensors that could be on the suspect list are:
Mass Airflow Sensor
Ignition/coils/spark plugs (some engines eat spark plugs in 15K miles)
Oxygen sensor, upstream
Throttle Position Sensor (this can fail with no code)
That should get you started. I am not saying these all have to be replaced, just tested. First thing to check is the plugs and not just a visual check. Measure the spark gap. Should be no larger than 0.035" but ideally 0.032". Once you get above 0.035" you'll start to lose power under high boost situations. Once you go over 0.038 you'll start having misfires and severe hesitation under heavy throttle. More than once I've helped a friend with hesitation like this and found out there's a worn out or damaged spark plug.
From there, clean the MAF and test the TPS as outlined in the factory service manual. The O2 sensor is about $50 on Amazon and can be replaced anyway if has never been done and should improve things a little.
326WHP 347TQ
Supercharger decals w/ no Supercharger(poser?) LuvmyRunner1980 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-20-2013 05:13 PM
WTB: TRD SUPERCHARGER 3.4 96-up ramminyota Want to Buy/Trade 2 03-12-2010 02:45 PM
trd supercharger riceandpho 4th Gen T4Rs 4 09-23-2009 06:52 PM
4th gen Supercharger Paulmessen Engines / Suspension / Wheels / Tires / Audio / Accessories 10 07-05-2006 07:21 PM
