08-01-2013, 05:00 PM
#31
Originally Posted by 4-Ripcord
It was me that said it, but potato potahto.
Its because the engine isnt in the optimal running temps at that low of temp range.
What's optimal?
I have water temp on my scangauge and once warm it is always dead nuts on 170F unless I have AC on (172-173F). Obviously this is just cruising around.
If I'm pulling up a steep hill I'll get into the 190F range.
08-01-2013, 05:35 PM
#32
Real Name: Vince
Real Name: Vince
Thanks Ripcord! Sorry for my misquote.
08-02-2013, 09:21 AM
#33
Real Name: Adam
Real Name: Adam
Originally Posted by J. B.
What's optimal?
I've had mine for 2 years, and its always been around 196-200* range. It can be cold or hot, its always within this range, even with the AC on. I haven't changed the thermostat since I bought it, so I can't tell you which one is in there...
08-11-2013, 10:57 PM
#34
Real Name: Tanner
Real Name: Tanner
Thanks guys! All the info here is amazingly helpful! I'm not looking to supercharge my 4Runner very soon, but I want to prep the runner for it and get some of the performance stuff done prior.
What is the best high flow cat I can get for my money. I'm going to pair it with a flowmaster 50 series muffler and definitely get the urd o2 adapter.
- 2000 Limited Desert Dune -
- CURRENTLY - Toytec BOSS C/Os, Total Chaos UCAs, OME 861s, FOX Remote Resi Rear Shocks, 315/75/16 Baja MTZs on Method Mesh Wheels, CBI Front and Rear Bumpers -
- Supercharged w/ 2.1 pulley, Tundra Brakes, and many others -
- HOPES AND DREAMS - Re-Gear, Fuel Mods and Tuning, Custom Rack, On-Board Air, and Shrockworks Full Skid Package -
08-20-2013, 10:33 PM
#35
Anyone figure out something for the accelerator and transmission bracket? I bought a supercharger from a guy with an '01 so he had the different bracket on there and I don't want to pay $170 for one stupid little bracket.
'98 SR5 Converted to '01-'02 Sport Edition
Matte Blue Vinyl Wrap - Black Interior - Too Many Mods
Build Thread
Instagram: 98trd4r
08-21-2013, 12:38 AM
#36
Real Name: Robert
Real Name: Robert
They look to be pretty simple to make, but I'm pretty sure
@ EatonKyleH
has an extra one. I'd pm him in regards to it.
Congrats on the purchase! What gen did you get?
My 4runner Build Thread 2000 Limited 4runner SOLD
My Tundra Build Thread 2006 Double Cab Tundra SOLD
My Humpty Dumpty 4runner Build Thread 1999 Highlander 4runner
08-21-2013, 12:44 AM
#37
@ EatonKyleH
I just picked it up today. It has mostly everything except that bracket and then the parts that come with the dynamic tensioner so I'm gonna have to get that. He even gave me an '01-'02 throttle body with it so I can sell that and make some money back.
Oh and I now realize you asked what gen did I get. I read that real fast and read when did you get it. Haha. But I got the 2nd/4th gen black one.
Build Thread
Instagram: 98trd4r
08-21-2013, 01:32 PM
#38
Real Name: Robert
Real Name: Robert
Thought there were only 2 gens? Gray is 1st, and black is 2nd?
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
08-21-2013, 02:17 PM
#39
It is a 2nd gen but its also called a 4th gen. I have no idea why.
Build Thread
Instagram: 98trd4r
08-22-2013, 06:47 PM
#40
Real Name: Sam
Real Name: Sam
4th gen is an Eaton designation. Only 3rd gen (grey called 1st gen by us) and 4th gen (black called 2nd gen by Us) were set up for use on the 3.4
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
09-24-2013, 10:10 PM
#41
96 3.4 TRD miss problem
Hi Supercharger yotas. I have a 96 TRD supercharger that I added in 2002 when my 4r had 120,000 miles. Recently I have been have my first problems with the engine missing when I get up to 2500 rpms. Wondering if anyone else has had this problem. So far I have, changed the fuel filter, fuel pump, fuel pressure regulator. Checked sensors, VSS, O2 sensors, cleaned and checked MAF sensor, checked for vacuum leaks. Unpluged knock sensors to see if that would stop the 2500 rpm miss. I did get a p0171 code once, but it didn't reoccur. Now the fuel trim readings and O2 readings seem normal. The MAF readings are just above normal readings for a standard aspirated engine I figure that is due to the supercharger. I have a exhaust gas temp gauge and the temps are normal. I'm about ready for the dynamite. Does anyone have experience with this problem?
09-28-2013, 09:54 PM
#42
For those with the TRD supercharger...Just out of curiosity once you put on the supercharger what type of gas are you running? Regular or Super??
2000 T4R Sport Edition - TRD Headers and Exhaust and 99 Highlander rear coils.
09-28-2013, 10:13 PM
#43
93 super always. Wish I could get higher. 93 normally works fine.
09-29-2013, 09:42 AM
#44
I believe super unleaded in mandatory once you add the supercharger. Us folks in CA, only get 91 out of our super unleaded unless you get race gas, not very practical.
98 4runner. L.A.M.B. (locked, armored, methanol injected & blown) URD 7th & 2.2 pulley, meth injection, ARB bumper & lockers, Warn 9.5xp winch, yukon 4.88 gears, rear disk conv, blah,blah, blah blah [B]SOLDB]
93 Hilux Surf, 3.0 kz-te, restoration in 3, 2, 1
09-29-2013, 05:05 PM
#45
What do you guys thinking of installing a S/C on a engine over 200k auto? S/C coming of Tacoma.
