09-28-2022, 07:12 PM
#4081
Was this a Magnusson S/C or the Toyota/TRD Labeled one?
That EO doesn't look right, is that part of a sticker that was provided or is currently installed on your 3rd gen?
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
09-28-2022, 08:34 PM
#4082
The 3.4L TRD Supercharger Thread
D-425-15 is the sticker TRD sent me directly after I installed mine second hand. Same sticker my smog ref ok’d for the engine swap on the same vehicle. It’s also the most up to date one. Another number guys have used is D-425-13. Reading the fine print of that is identical except for effective date. It also says “trucks”. The smog guy is scared.
Wanted to add mine has been smogged 6 times at 3 different shops under that EO sticker. Tailpipe is clean enough to pass and I’ve never had a single syllable of issue from the state. This dude is a weiney. I’d call TRD or Magnuson direct and see if they can tell you which sticker is right and that should end it.
09-29-2022, 01:11 AM
#4083
anyone run a separate ECU like haltech or link?
09-30-2022, 01:30 PM
#4084
Real Name: Jerod
Real Name: Jerod
Sounds like you've been on the facebook page where just two guys spam the Haltech as the 'cure all for all performance needs'. The Haltech system when you add the ECU, parts, labor and tuning is well over $3,000, about the same as the supercharger itself. I haven't even spent $3,000 in performance parts on my entire build, let alone one component. A standalone ECU like the Haltech replaces the stock ECU completely so if you live in an area that requires smog checks you cannot do it and remain smog legal so keep that in mind. A piggyback ECU is added to the stock ECU and although it technically isn't legal either, it will still pass smog every time. That would include ones like the MAP3ECU, AIM FIC 6, and URD's SplitSecond system.
Any aftermarket ECU, whether a standalone or piggyback, requires a knowledge of your vehicles' wiring as well as basic tuning skills to get it running. It's not for the faint of heart as there is some risk involved (URD's system is the simplest to install). I have some install notes from my piggyback ECU installation if you're interested in the link in my signature, as well as there is a URD 7th injector tuning guide here on the forums.
In my opinion, half the guys flaunting the Haltech are doing it just to shoot flames out the tailpipe with a spark cutout at redline instead of the original fuel cutout. There's a reason why Toyota cuts fuel and not spark. As the guy on facebook who used to respond to every post with 'get a haltech' who just blew his engine up after less than 6 months with the Haltech 'tuned' for his vehicle.
10-07-2022, 02:55 PM
#4085
excellent - thank you. def. apprecaite your knowledge on this.
10-07-2022, 05:02 PM
#4086
Is there even a base timing and fuel map for the 5vz to use in a standalone ecu? I have a mega squirt on another car and it would be super hard to tune without a base map. The haltech guy that blew up his engine isn’t the first person I’ve heard about blowing a motor trying to tune a stand-alone ecu
10-07-2022, 08:13 PM
#4087
Real Name: Jerod
Real Name: Jerod
I believe that LCE Performance would be the closest thing as they sell a Haltech kit just for Toyota trucks, although I don't know this for sure. Purchased anywhere else though and you're exactly right, you'd be in the dark as where to start. I don't even know if it comes with things like the spark plug firing order or not.
01-16-2023, 08:35 PM
#4088
Newly Acquired First Gen Supercharger
Hey everybody, I just picked up a supercharger off of my friends truck and wanted to get peoples opinions regarding how deeply it should be rebuilt (and what kit I should buy for the rebuild) as the mechanic who took it off the truck said he is willing to rebuild it for me.
This charger has around 230k miles and looks to be in pretty good condition with regular oil changes.
https://youtube.com/shorts/e7SSmVKQEm0?feature=share
I have included a video of the charger running before we took it off the truck. I'm in no rush to get this charger on the truck but want to go down the best possible route to try to eliminate any headaches down the road. Let me know how you guys think it sounds and looks!
2000 4Runner Limited Supercharged, Eibach/OME 890, 2" Coil Spacer, Fat Pats 1.5" body lift, 285 Duratracs, 2 12" Pioneer champion pro series subs, 231mm TBU, Camburg UCA's, SCS SR8's Dark Bronze, Sonoram Steel Panhard Bar, '02 Sport Hood, other little things.
01-17-2023, 04:50 PM
#4089
Real Name: Jerod
Real Name: Jerod
1999 Supercharger Idling - YouTube
Well, it looks like a 20 year old auto part but thankfully looks don't matter much on a supercharger. I struggled a bit to discern through the audio what was engine and exhaust noise and what was supercharger noise so let's just assume it needs a rebuild. That would be the rear needle bearings in the back of the rotor housing, as well as the nose cone bearings, oil seal and new oil.
I have been using Rolling Performance Home for years, and yes the website really is that old. Get the rebuild kit for the TRD M62 unit, not the others listed on his website and pay for the Viton seal as I've had the older seals leak on me and you don't want to have to do it again. Also pick up a coupler and a set of rear rotor bearings, again the ones for the TRD M62.
The 1st gen or gray superchargers tend to develop vacuum leaks along the gaskets that seal the various intake parts. Make sure these are not leaking but don't disassemble if you do not have to as the gasket may get worse if you do. They are hard to source now so many end up using a liquid gasket and lots of luck.
All in all you should have it rebuild for $200 or less, depending if you need a machine shop to do any presswork for you or if you are more creative like I am and where's there's a will, there's a way.
01-18-2023, 06:25 PM
#4090
Curious, has anyone successfully rebuilt their bypass valve? Just smoke-tested my intake/vacuum system trying to source my P0171 code and the diaphragm on my 1st gen bypass valve is DONE.
Seeing if I have any options before I spend ~$200 on a new unit.
- Tyler
Instagram - TF_Tyler
'98 LTD | Misguided and poorly planned
01-18-2023, 06:50 PM
#4091
I saw a couple months back that magnuson is coming out with a new supercharger for the 3.4. Looked pretty sweet, might have to get one.
01-18-2023, 07:31 PM
#4092
That would be interesting, so Magnuson has continued development on a supercharger for an engine no longer produced?
01-18-2023, 11:46 PM
#4093
Seems like it, they had it on their Instagram story and said it would be released early this yr. I was surprised as well when I saw it lol.
01-19-2023, 11:37 AM
#4094
Would be interesting if they were developing something different, but like already stated, seems kinda odd they'd develop something for an engine they stopped putting in vehicles almost 20 years ago.
I do want to purchase one from them still, but last I heard they had to switch to a press-on pulley instead of the bolt-on, and there aren't any smaller pulley options for that style.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
01-19-2023, 01:25 PM
#4095
Real Name: Jerod
Real Name: Jerod
I cannot say it has never been done but if you were attempt to repair it would be the first I have heard of. If you are not depending on the vehicle to run they why not? It is already broken, cannot make it any more broken than it is. Worse case is that you buy a new one.
They have a prototype that has the newer 4 lobe TVS rotors instead of the old 3 lobe style. It was shown at an auto show late last year. As anyone who has followed the auto industry knows, just because there is a prototype, doesn't mean it will go into production.
The other piece is cost. The current ones are $3,500 new. What would the newer design need to cost to recoup their R&D and manufacturing costs? $5,000? I could buy a whole 4Runner at that price, or just one part that adds 60 HP. Hmm.
