Old 07-13-2013, 11:11 AM #1
nicolasballia's Avatar
nicolasballia nicolasballia is offline
Real Name: nicolas
nicolasballia is on a distinguished road
Real Name: nicolas
Transmission fluid options
So i have my 1998 4runner and i dont believe its ever gotten new fluid on the transmission. i have heard that if a vehicle has a lot of miles (mine has 132xxx) and its never gotten a fluid change on the tranny that it is better to just leave it alone because the flush might ruin all the seals inside the tranny.others say that it doesn't matter and just to do the flush.
i was thinking dropping the pan about three or four times until all the fluid or at least most is changed.
What do you guys think is the best way to go about this?
nicolasballia is offline   Reply With QuoteReply With Quote
Old 07-13-2013, 02:43 PM #2
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
You can do the at home type flush using the cooler lines to drain the fluid or do several drain and fills. Either way is fine and won't hurt the trans at all.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 07-13-2013, 03:46 PM #3
Real Name: nicolas
Real Name: nicolas
is there a writeup somewhere for the home flush? I dont think i ever heard that before.
Old 07-13-2013, 04:02 PM #4
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
Robb235's Avatar
Real Name: Robert
What trans fluid do these even take? Lol I've never even looked.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 07-13-2013, 04:41 PM #5
kball's Avatar
kball's Avatar
For starters I should ask, you do have an auto trans right? If so follow the steps in this link. He drops the pan and does a really complete cleaning job of it but you don't have to. Skip down to step 37 and start there.
Dropping Pan And Flushing Transmission
These transmissions take Dexron III or better. I usually use Valvoline Maxlife Dex/Merc or Dexron VI. Both of these are synethic blends. The Maxlife is very inexpensive and seems to be good stuff so I usually get that.
236K miles
Old 07-13-2013, 06:44 PM #6
Real Name: nicolas
Real Name: nicolas
Yes, sorry. I do have an auto. Ive had it since 128k and im uncertain of tranny services
Old 07-13-2013, 08:22 PM #7
Peak's Avatar
Peak Peak is offline
Real Name: Jonathan Hoppman
Peak is on a distinguished road
Peak's Avatar
Doing a full flush is probably best...
1992 Lexus SC400-149k 1999 Lexus GS300-168k
1999 Mazda MX-5 Miata-135k 2001 Toyota Sequoia Limited-225k 2003 Chevrolet Suburban 4x4-164k 2000 Mazda Miata Special Edition-1 0f 3k-99k 1996 Ford Explorer Eddie Bauer 4x4-197k all LEXUS!!!
Peak is offline   Reply With QuoteReply With Quote
Old 07-13-2013, 08:29 PM #8
Real Name: nicolas
Real Name: nicolas
My dad keeps telling me that since the.oil is.old if i put new fluid with all the additives and cleaning properties that it could wash off the seals or the pressure would mess the seals up. To b4 honest i don't have enough knowledge on transmissions to know what's best
Old 07-13-2013, 08:36 PM #9
Nunyabiz's Avatar
Nunyabiz Nunyabiz is offline
Nunyabiz is on a distinguished road
Nunyabiz's Avatar
Drop the pan, check everything out, check the magnets etc.
If all looks OK seal it back up, add a bit of regular ATF.
Take it to a transmission shop that has a Ttech machine which will replace every drop of ATf with new ATF without doing a "flush" it simply uses the pump to push new in and old out.
Use 100% Synthetic fluid and take a qt or 2 more than needed.
I use Amsoil, though I am sure any 100% synthetic is fine.
2002 3.4L 4X4 Sport Edition
Nunyabiz is offline   Reply With QuoteReply With Quote
Old 07-14-2013, 01:26 AM #10
Kanger328 Kanger328 is offline
Kanger328 is on a distinguished road
I used the tranny cooler line method. I used Amsoil also, but warning...Amsoil is EXPENSIVE and can only buy online (as far as I know). If you're going to use the cooler lines method and plan to add a tranny cooler, do it at the same time.
1996 Limited 4x4 Anthracite Metallic (162,XXX miles)
-OME 881/890 with Tundra Bilstein Struts/Bilstein 5100 rear, 16" 5-Stars with 265/75R16 Duratracs, Savage Sliders and Skids, B&M 70268 Trans Cooler, Amsoil Fluids
Kanger328 is offline   Reply With QuoteReply With Quote
Old 07-14-2013, 02:22 AM #11
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
you can't easily do a home "flush"
you can do a home "drain small percentage of total trans fluid and refill"
A flush is done by a machine that pushes out all the old fluid and pumps in the new fluid.
$165 at the Toyota dealer last time I checked. I did mine a few years ago.
I wouldn't get it done at a cheap oil change shop, take it somewhere that works on Toyotas.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 07-14-2013, 08:59 PM #12
biodieselLuke biodieselLuke is offline
biodieselLuke is on a distinguished road
my jiffy lube has a t-tech machine and sells amsoil? I usually drop the pan, replace the filter, replace the pan, add however much fluid came out, then drive it over and have "Jim" replace all my fluid. I watched him do it the first few times to make sure there werent any shop practices going on that i dont agree with...... now i just drink their coffee and wait in the ac like everyone else............... course if jims not there i come back when he is
98 4Runner V6 4x4 SR5
Lots of fords
lots of mercedes
all of em diesels
biodieselLuke is offline   Reply With QuoteReply With Quote
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
What transmission fluid do you use? vthokie 3rd gen T4Rs 5 08-17-2011 03:36 PM
Transmission Fluid? BlaznAzn 4th Gen T4Rs 1 04-02-2007 08:49 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
What about our Transmission fluid??? wsudu 3rd gen T4Rs 6 06-29-2005 11:37 AM
