Old 07-31-2013, 03:48 PM #1
browningcrew24 browningcrew24 is offline
browningcrew24 is on a distinguished road
Misfiring with no codes
So first time poster cause i cant get the answer I need via the search tool. ive got about 500 miles on the 97 limited 3.4 V6 I just bought....there is 171K total. There is for sure a misfire going on and it seems to come and go mostly at idle and when ive been stopped for more then a min but the CEL has not come on for anything but P0120, P0446, and P0420. Regarding the 446 I was told its just the gas cap and not to worry about it, the 420 (cat) sounds like it might be happening because of the misfire or an o2 but isnt going to be the cause of the misfire, the 120 (TPS) is the only thing that I think could cause this but based on some threads ive searched ppl think it cant cause a misfire or poor running?? Anyways the maintenance ive done on this is:
plugs and wires (attached pic what the plugs coming out looked liked and what the plug I put in was)
Misfiring with no codes-img_8233-jpg
changed oil and filter
new fluids in diffs and t case
cleaned MAF and throttle body
just changed fuel filter which seemed to help but not fix......had a fram on it?
oh i also changed one of the coil pack boots cause it looked bad all cracked and rusty... but not the other ones...they had some hard white residue that i removed and just reused them...is this bad?
Misfiring with no codes-img_8237-jpg
anyways before I replace the TPS I just wanna know any others opinion! any help would be greatly appreciated!
browningcrew24 is offline   Reply With QuoteReply With Quote
Old 07-31-2013, 11:36 PM #2
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
What's your idle speed? Maybe your tps is messed up or maybe your IAC needs cleaning and you're idling to slowly.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 08-01-2013, 02:39 AM #3
I heard that I shouldnt try to gap the platinum plugs which I gaped when I changed the spark plugs which could have ruined them?? I bought six new ones but the are all gaped at .40 but they are spose to be at .44 for the runner! Is it ok to use them at .40? and could this ultimately be the problem?
Old 08-01-2013, 08:53 PM #4
so I replaced the PLugs this morning and its running 95% better I believe i must have messed the other one up when I gaped them (broken electrode?)...the only thing that is happening now is a slight hesitation every 5-10 seconds when stopped at a light or in park...could this be a TPS? Havent had any other codes come back since I cleared them...been about 150 miles. And to answer your question no there is no play in RPM when at idle even with small hesitation!
Old 08-02-2013, 01:26 AM #5
BlazeRunner's Avatar
BlazeRunner BlazeRunner is offline
BlazeRunner is on a distinguished road
You need two pronged plugs for that motor. If you haven't noticed already, there is one coil for two plugs, each being fired simultaneously. I just did my fuel filter and plugs, along with cleaning my MAF and throttle body and it has eliminated all problems of hesitation, long starts, sluggish throttle, rough idle... in other words - it feels like a new motor. Start with some correct plugs and go from there. Try NGK BKR5EKB-11
Edit: reread and saw you cleaned throttle body and MAF, should help. Sorry I really don't have experience with TPS issues but I just wanted you to have the right plugs
1997 4Runner Limited 4WD w/factory RR Diff Lock (4.30:1), Blue Wire Mod, KYB monomax & 'tall' coils, Falken Wildpeak AT3W 265/75 on 16x8" Raceline 887's(+1" spacing), K&N CAI, Tru-cool 4589 bypass, TB gasket mod, OEM sport hood, Satoshi style grill, steel front skid and more
"Do not go where the path may lead, go instead where there is no path and blaze a trail."
BlazeRunner is offline   Reply With QuoteReply With Quote
Old 08-02-2013, 09:18 AM #6
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
If you have not replaced the O2 sensors, start there first.
Also this engine due to the ignition system it utilizes shines using the aformentioned dual electrode plugs in it. Don't believe that all plugs have the correct gap out of the box.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-02-2013, 11:24 AM #7
OK well I'll throw the duel electrode plugs in and see if it helps...if not I'll look at o2 sensor...could this have anything to do woith the timing belt the previous owner did himself about 2000 miles ago??
Old 08-02-2013, 11:52 AM #8
the1998sr5 the1998sr5 is offline
the1998sr5 is on a distinguished road
What condition is your alternator in? I ask because if it is not producing enough power you can misfire-this typically will produce no codes.
the1998sr5 is offline   Reply With QuoteReply With Quote
Old 08-02-2013, 12:15 PM #9
doesnt seem to have any other symptoms so I think its prob fine.
cylinder #3 misfiring blackberrius 3rd gen T4Rs 7 08-26-2013 07:12 PM
Misfiring? Timing off? 02runner4 3rd gen T4Rs 15 11-21-2012 12:17 AM
Misfiring on 3 cylinders FoneRunner 3rd gen T4Rs 9 05-02-2011 01:38 PM
91 4runner v6 misfiring ???? vergotex3 Classic T4Rs 5 01-30-2011 11:52 PM
Misfiring but don't know why dolezal83 Classic T4Rs 5 01-14-2009 10:26 PM
