Time is of essence. Assuming that it was not a salt water flood.
Remove the sparkplugs.
Turn engine over to dry cylinders out.
If there is no lock up or mechanical grinding noise. All is good.
Change oil.
Install new plugs and use plenty of Wd40 On the spark plug boots and coil packs.
Start it up.
If you have no fire or fuel, you will need to remove the ECU, flush it with distilled water, dry and re-install. Try again.
I know about flooding 4runners...
1999 Limited 4runner in
Silver -
9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap -
AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers &
adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax -
Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes -
V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in
Silver On 37's and
Guns for sale
