Old 08-05-2013, 01:43 AM #16
TX_QtPi TX_QtPi is offline
Real Name: Cynthia
TX_QtPi is on a distinguished road
Real Name: Cynthia
haven't used them but here is their local info, plus their webpage seems not to be working.
IMHO, I'd be leery of a company who claims to be importing used engines from japan.
Cynthia
JDM ALLIANCE
575 S International Rd Ste 400
Garland, TX 75042
(972) 494-4900
Website: http://www.jdmallianceusa.com
TX_QtPi is offline   Reply With QuoteReply With Quote
Old 08-05-2013, 02:00 AM #17
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
You need to diagnose your engine more before you come to the conclusion that you have a mechanical failure.
SV_Dude is offline   Reply With QuoteReply With Quote
Old 08-05-2013, 02:09 AM #18
Gho5t5niper Gho5t5niper is offline
Gho5t5niper is on a distinguished road
The engine hits a stopping point when we try to hand crank it so it probably means a bent rod right? I dont know what else it could be. Just hits and you hear a huge clunk like metal hitting metal and it wont turn any further in that direction.
Gho5t5niper is offline   Reply With QuoteReply With Quote
Old 08-05-2013, 02:20 AM #19
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
My advice is the same as what was given to you in the other thread. Pull the plugs and let everything dry. Check your oil and make sure you don't have a bunch of water in it. If you do then change your oil. When everything is dry, replace your plugs and try again.
A stoppage with the engine hardly means a bent connecting rod. For all you know, that metal sound could be a valve that is stuck or dropped. Have you looked inside the cylinders through the spark plug holes to see if you can see anything in there? Either way, I think you're seriously jumping the gun with a new engine.
Old 08-05-2013, 02:23 AM #20
Its been drying since last Sunday when it happend with still no luck. Took the plugs out and sucked the water out of the cylinders and let it set for 3 days and tried to start it again with no luck.
Old 08-05-2013, 07:07 AM #21
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Is there any way to drop the oil pan to get a visual? If not, you have to pull it anyway. Take it out, flip it over and see whats going on. I'm thinking you have a bent rod. What about rebuilding the engine you already have?
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 08-05-2013, 07:46 AM #22
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
The only reason you'd need a new motor is if the block cracked. I'll say what I said in the other thread too, get the thing out of your truck and on a stand so you can tear it down and see what happened. It's probably repairable/rebuildable, and you'll save a ton of money and have a brand new engine when you're done. If the block IS damaged, then hie thee to the junkyard and get a new block for a couple hundred bucks, then rebuild that.
Replacing your motor with a used block of unknown provenance is sketchy and asking for trouble. Those JDM motors are a deal for folks who don't have the space or tools or time to fix their own junk and can't afford to pay a mechanic to rebuild. You don't seem to fit that description, so don't be scared of the wrenches.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 08-05-2013, 08:26 AM #23
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Seems like the general word here is to diagnose your problem before you fix it. Throwing money on a new engine at this point doesn't make sense.
Btw, ill move your threads to the appropriate generation sub forum where you'll get more help on your engine.
Old 08-05-2013, 09:01 AM #24
lowlinkin's Avatar
lowlinkin lowlinkin is offline
Real Name: Brian Killebrew
lowlinkin will become famous soon enough
lowlinkin's Avatar
Hey for what its worth I've bought a couple of Japanese spec motors for Hondas and they have all worked out great. After so many miles it costs more in taxes than its worth to keep the car so the car is scrapped and a new one is bought. I would buy one over a junk yard motor because if you get it from a reputable company they will warranty it for a short time.
lowlinkin is offline   Reply With QuoteReply With Quote
Old 08-05-2013, 01:11 PM #25
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
Time is of essence. Assuming that it was not a salt water flood.
Remove the sparkplugs.
Turn engine over to dry cylinders out.
If there is no lock up or mechanical grinding noise. All is good.
Change oil.
Install new plugs and use plenty of Wd40 On the spark plug boots and coil packs.
Start it up.
If you have no fire or fuel, you will need to remove the ECU, flush it with distilled water, dry and re-install. Try again.
I know about flooding 4runners...
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 08-06-2013, 12:23 PM #26
Change oil.
Start it up.
Haha looks like you've been watching too much duck dynasty! You got yourself a nice duck blind started!
4runner , engine , flood , flooded , jdm , toyota , water
Flooded engine Whalergang66! General Discussions 5 07-14-2012 06:53 PM
Flooded engine Whalergang66! Maintenance/Detailing 0 07-11-2012 10:50 PM
Flooded 3rd gen socal!!! driffter33 General Discussions 4 03-22-2011 01:37 PM
so I FLOODED my truck T?@\7 4th Gen T4Rs 25 03-05-2008 08:07 PM
Flooded carpets - best way to dry them. tomzapf Off-Roading 9 08-26-2007 12:08 AM
