Old 08-01-2013, 11:48 PM #1
Gho5t5niper Gho5t5niper is offline
Gho5t5niper is on a distinguished road
Flooded Engine
Hey guys I have a pretty bad problem.. I was doing some offroading through some flood waters after a constant 3day rain. I must have hit the water a little too fast and water came up over the hood and stalled the engine. I tried starting it once while I was still in the water without any success it just clicked. I got pulled out in about 5 minutes after my engine stalled. Tried starting it after I was out of water and same clicking. I ended up having to get towed home by a friend.
Since then I replaced the starter and the engine makes a different sound when attempting to start but it still doesn't turn over. We took the spark plugs out and sucked water out of the cylinders that my k&n cold air intake sucked in. But it still wouldn't start. I forgot to mention that I checked the oil right after it happend also and there was no water in the oil.
We took the starter off again and tried to turn the engine by hand and it turns backwards fine but there is a spot where it just hits something and won't turn any further. Anybody have any ideas next??
Gho5t5niper is offline   Reply With QuoteReply With Quote
Old 08-01-2013, 11:59 PM #2
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
What year, what engine?
V8Man is offline   Reply With QuoteReply With Quote
Old 08-02-2013, 12:06 AM #3
zeak's Avatar
zeak zeak is offline
zeak is on a distinguished road
zeak's Avatar
If it seems to "hit something", I'd say thats bad....
Liquid will not compress at all, so theres a good chance that something else had to give when the water got in. Had an old chevy step-side with a 350 in it. I did the same thing you did. It cracked the skirt on one of the pistons. Which ever cylinder was on the compression stroke when it got flooded is the one the might have taken the worst of the damage.
It might be hitting a valve that got stuck open or bent.
Best of luck.
1991 4runner
zeak is offline   Reply With QuoteReply With Quote
Old 08-02-2013, 12:18 AM #4
Sorry, 1998 3.4 v6
Old 08-02-2013, 03:18 PM #5
Bump
Old 08-02-2013, 03:21 PM #6
Gadget Gadget is offline
official vendor
Gadget is an unknown quantity at this point
official vendor
Take out all the spark plugs.
Crank the engine until water stops shooting out of the plug holes.
Spray WD-40 into the cylinders and repeat.
Reinstall the plugs and hope for the best, but you may have bent a rod at this point.
G
www.GadgetOnline.com
www.URDUSA.com
Gadget is offline   Reply With QuoteReply With Quote
Old 08-02-2013, 03:41 PM #7
dorton's Avatar
dorton dorton is offline
dorton is on a distinguished road
dorton's Avatar
Originally Posted by Gho5t5niper View Post
Hey guys I have a pretty bad problem.. I was doing some offroading through some flood waters after a constant 3day rain. I went through water up to my headlights and it made it through like a champ. I had to turn around and go back through the same hole because the rest of the road was twice as deep. As I was going back through the same hole I must have hit it a little too fast and water came up over the good and stalled the engine (I have a video I will try to post). Water started coming in through the doors and the interior got flooded. I tried starting it once while I was still in the water without any success it just clicked. I got pulled out by someone passing by about 5 minutes after my engine stalled. Tried starting it after I was out of water and same clicking. I ended up habits get towed home by a friend.
Sounds expensive.
Pull the plugs, keep your head clear, and turn it back over with the starter. You can use a wooden dowel rod to drop in the cylinder when turning the motor over by hand to see if one piston doesn't come up as much as the others.
dorton is offline   Reply With QuoteReply With Quote
Old 08-02-2013, 09:09 PM #8
BucknutBob's Avatar
BucknutBob BucknutBob is offline
BucknutBob is on a distinguished road
BucknutBob's Avatar
Well, you got around to pulling the plugs a bit too late in the process--you should've done that FIRST before trying to restart it after it died. It does no good to go that route later, as you've already hydro-locked the beast and likely stress-cracked lots of expensive parts. Even if you do get it to run again, it likely won't be too far down the road before something goes "boom". If you kill an engine with water, you need to evacuate the water BEFORE trying to start it again--once you crank it with non-compressible water in there, you do permanent damage.
Former owner of four Runners: three 2nd Gens and one 1st Gen. Idle for now, but will be back in one again before too long.
BucknutBob is offline   Reply With QuoteReply With Quote
Old 08-03-2013, 02:18 AM #9
So if it really is a hydro locked engine or a bent rod is there anything I can do at all? I need to start weighing my options. Insurance wont cover a dime I suppose since I got into this mess myself. A new engine is 4,000 and I bought this 4Runner for 5,000 with 210,000 miles on it.
Old 08-03-2013, 03:21 AM #10
zeak's Avatar
zeak's Avatar
I would start looking on CL and salvage yards in your area. An engine swap is not very hard if engine A and engine B are the same. You might also consider an up-grade wile you have everything apart....
1991 4runner
Old 08-03-2013, 06:07 AM #11
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
wow!..tough one
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 08-03-2013, 06:27 AM #12
BucknutBob's Avatar
BucknutBob's Avatar
I'd look into a long-block assembly from someone such as "toyotacarpart.com" and swap over the external pieces from your current engine. You can get one of those for less than two grand (unless their prices have jumped dramatically since the last time I checked). As zeak mentioned, a same-for-same swap isn't that difficult if you have a couple buddies and an engine hoist.
Old 08-03-2013, 08:27 AM #13
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
You'd be surprised what insurance will cover if you have a good agency. Give it a shot.
Do you have a couple weeks to mess with it? Get a junkyard block and rebuild it. Then swap it in, and tear yours down and see if it can be rebuilt and sold. If so, you might come near breaking even.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 05:53 PM #14
Well I found a couple of engines that arnt too expensive right around 1.5k, they are all jdm which evidentially imports motors from Japan. My question is are they good quality? Has anybody used them and what's your feedback? Most of these have under 60k miles on them. Are there any issues? Know anybody that has used them? Thanks guys!
Old 08-05-2013, 01:33 AM #15
JDM Engines???
Well I found a couple of used engines after i flooded mine and most likely bent a rod. They arnt too expensive right around 1.5k, they are all jdm which apparently imports motors from Japan. My question is are they good quality? Has anybody used them and what's your feedback? Are there any issues? Know anybody that has used them? Thanks guys! Most of these have under 60k miles on them.
Here is one of them that i was looking at.
http://www.ebay.co.uk/itm/JDM-Toyota...item3f279b5071
1998 4Runner 3400 v6
4runner , engine , flood , flooded , jdm , toyota , water
Flooded engine Whalergang66! General Discussions 5 07-14-2012 06:53 PM
Flooded engine Whalergang66! Maintenance/Detailing 0 07-11-2012 10:50 PM
Flooded 3rd gen socal!!! driffter33 General Discussions 4 03-22-2011 01:37 PM
so I FLOODED my truck T?@\7 4th Gen T4Rs 25 03-05-2008 08:07 PM
Flooded carpets - best way to dry them. tomzapf Off-Roading 9 08-26-2007 12:08 AM
