07-11-2020, 10:55 PM
#361
official vendor
official vendor
Some changes will be taking place tomorrow.
07-12-2020, 10:45 PM
#362
official vendor
official vendor
My work started last night with draining the oil, and transmission fluid. Getting the front end up on stands, and stopping there for the night. Today I filled the transmission fluid, and finished the oil change. Next up was removing my old Bilsteins, LBJ's, inner TRE's, outer TRE's, and rear sway bar links.
After getting everything installed I went ahead and applied grease to my front UCA's, rear LCA's, and my drive shafts. I was starting to get a little bushing sqeak from the lack of maintenance on them. I still have a little work to do on my roof rack, and rear swing out before heading out.
07-13-2020, 11:51 AM
#363
Real Name: Jeff
Real Name: Jeff
I somehow was still subscribed to your thread but wasn't getting notifications! This is some awesome work mike! You'll love those Kings. I'm glad your still in a 3rd gen. Keep up the good work!
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
07-13-2020, 02:41 PM
#364
official vendor
official vendor
I need to adjust the Kings to lower the front down about an inch, and then I'll be ready to take her for a drive. We've decided to keep the 4runner rather than selling it. I have some more things that I need to address, and some additional repairs that need to take place. But, I think the 4runner will be around for quite some time.
Mike
07-21-2020, 10:48 AM
#365
official vendor
official vendor
07-21-2020, 10:51 AM
#366
official vendor
official vendor
Started on a new project last night, and hoping to have it finished tonight or tomorrow night.
I replaced the charcoal canister a while back, and have had some issues after filling tank ever since. I started getting a strong smell of gas while filling, and that usually means the purge valve/gasket are shot. Well, over the weekend it was so bad that the gas pump would kick off, and we couldn't get gas. Denting the skid didn't help, but was motivation enough to get it fixed.
I'm going to be replacing the filler next, purge valve, valve gasket, gas cap, and adding a rear diff breather.
07-23-2020, 09:56 AM
#367
official vendor
official vendor
08-03-2020, 02:25 PM
#368
official vendor
official vendor
The new tank, purge valve, gasket, filler neck, evap hose, and gas cap are installed. I was able to drain the gas from the old tank, and get into the new tank without any issues. I still need to fix the exhaust, but the 4runner did fire right up.
08-04-2020, 01:52 PM
#369
Real Name: Jeff
Real Name: Jeff
Hey that's a good feeling! Congrats. Any plans for a gas tank skid?
Build
08-13-2020, 12:00 PM
#370
official vendor
official vendor
I thought about getting a Lil' Skip's skid, but decided against it. I've only had one time where I wish I would have had one, and I feel that money would be better spent on my new project.
Mike
08-13-2020, 12:39 PM
#371
Real Name: Jeff
Real Name: Jeff
I can totally understand that. I've seen people weld reinforcements to the OE skid. Just a though. Way cheaper than buying one.
Build
01-02-2021, 08:05 PM
#372
official vendor
official vendor
01-02-2021, 08:24 PM
#373
Sliders
It’s weight, to be sure, but you’ll be thankful you have them should anything kick up into your rocker. Btw, your mount on my 2000 still works and looks great!
01-02-2021, 09:30 PM
#374
official vendor
official vendor
She's mostly a pavement princess, but they will make life easier for loading/unloading things from the roof rack. We really only get the 4runner off-road a few times a year when summer comes.
Glad to hear the mount is still working out for you.
Mike
01-02-2021, 10:02 PM
#375
official vendor
official vendor
