Old 06-08-2014, 03:06 PM #16
mmml4's Avatar
mmml4 mmml4 is offline
mmml4 is on a distinguished road
mmml4's Avatar
I would at least price them from the dealership, might not be as $$$ as you think. I bought a hard line from the center of the axle to the caliper on my Land Cruiser rear axle and it was only $14.00. Just a thought. On a personal note, I hate flaring tubing never seems to go my way.
99 4runner SR5 3.4 auto, in the rebuild/build process
2wd to 4wd, SAS, 80 series LC axles and transmission
My Build, http://www.toyota-4runner.org/3rd-ge...ild-build.html____________________________________________
"The significant problems we face cannot be solved by the level of thinking that created them" Albert Einstein
mmml4 is offline   Reply With QuoteReply With Quote
Old 06-08-2014, 03:09 PM #17
nobb nobb is offline
nobb is on a distinguished road
Maybe in the states, but here in Canada dealers gouge us for parts. Last time I priced it out I think it was ~$80 per line.
I might drive down to Montana in the next few months so perhaps it's worth getting them there...
nobb is offline   Reply With QuoteReply With Quote
Old 02-02-2016, 03:46 PM #18
mrsharky mrsharky is offline
Real Name: Matt
mrsharky is on a distinguished road
Real Name: Matt
sorry to dig up an old post like this....
Has anyone done this recently? I talked to my local dealership, and they said the hard brake lines were NLA, and recommended I call Napa. They told me to bring 'em in and match 'em up. Anyone have it documented what size brake lines are needed?
thanks in advance.
Matt
mrsharky is offline   Reply With QuoteReply With Quote
Old 02-02-2016, 03:59 PM #19
3/16" diameter, M10 x 1.0, 45 degree Japanese flare. The OEM length that I measured was 10" front (both) and 34" rear driver's side, 35" rear passenger side. However, I used precut lines that were 12" front (both) and 30" rear (both). 30" was a bit tight in the rear but I got it to fit by not using all the OEM mounting points.
Old 02-02-2016, 08:42 PM #20
Real Name: Matt
Real Name: Matt
Awesome, thanks!! In the front on mine, there is an adapter/joiner that goes at a right angle on the frame - does it serve a purpose? Also NLA from the dealership, and I'm not sure mine is re-usable. I have to assume it does, but it would be a lot easier to just bend the line and have one piece. Will post a picture if I can figure it out.
Matt
Old 02-02-2016, 09:07 PM #21
I'm not sure what adapter you are talking about. I only replaced the hard lines from the rubber hose to the wheel end.
Old 02-03-2016, 08:53 AM #22
Real Name: Matt
Real Name: Matt
Hopefully this shows up....
http://i1116.photobucket.com/albums/...rakeAngle.jpeg
This is the part I'm talking about - it's an "L" Junction between two hard lines - this is passenger side wheel well - I was doing the starter and the line started to ooze from being moved. Pretty rusty, so I don't mind replacing it. Just wondering if I can remove that part and just do a bend in the brake line, or if it's serves some function.
Matt
Old 02-03-2016, 10:18 AM #23
cfranck1's Avatar
cfranck1 cfranck1 is offline
cfranck1 is on a distinguished road
cfranck1's Avatar
Matt
Matt,
This looks like what you're looking for??
This elbow should still be available from Toyota, They just replaced it on my Tacoma when they did the frame replacement.. I could only assume that it is the same part from 4Runner to Tacoma??
I'd call Toyota with the part number from the picture?!
Hard Brake Line Replacement. Pre-bent or DIY (what's the specs)?-brakeline-2-way-jpg
01 SR5 - 187k+/- 285 BFG A/T KO2 - 99 talls & front Trekmasters / Rear KYB - Hella fogs - Taco Mod - Fixed gaping hole in frame {SOLD}
02 Taco - 197k +/- BFG A/T KO2 285s + rims from 4Runner - saving up for suspension - House gets priority over Taco (for now)
cfranck1 is offline   Reply With QuoteReply With Quote
Old 02-03-2016, 11:01 AM #24
It looks to be just a union to make it easier to join two sections of line, but I would replace the part. I'm assuming you're replacing the upper section with the coiled line (for strain relief) as well? That might have to be an OEM part, no way to build that.
Old 02-04-2016, 12:36 PM #25
Real Name: Matt
Real Name: Matt
That is the part, pretty sure. I do think it's just a junction, but I would be afraid to leave it out, and not sure mine is reusable.
Just called the dealership... $18 to get it, hopefully they have it tomorrow. Only 12 left in the country.
Thanks all for the help!!
Matt
Old 02-04-2016, 12:38 PM #26
Real Name: Matt
Real Name: Matt
Yes, I am replacing that line and the other line going out of the connection. None of the hard lines were available from the dealer, so i'm going to be building them. Hadn't thought of that coil as a functional thing... guess I will duplicate it in my line.
Matt
Old 02-04-2016, 12:42 PM #27
Cool, would be interested in seeing pics when you're done. I guess you could bend the coil by wrapping your lines around a large dowel. Definitely don't leave it out...it's there for stress relief from vibration/temperature.
Old 02-04-2016, 03:56 PM #28
Real Name: Matt
Real Name: Matt
I will definitely get some pix posted as soon as I'm done.
Maybe a stupid question, but what is "Japanese flare"? I'm familiar with bubble, inverted & double.... not sure what "Japanese" flare is....
and do I need 37 pieces of it?
Old 09-04-2016, 10:27 AM #29
EchoBase EchoBase is offline
EchoBase is on a distinguished road
Digging this up because no one has answered this through the whole thread.
It's a double flare, never heard of Japanese flare before.
Use the die that fits into 3/16 line and compress it until it bottoms out on the yoke. Remove the die and compress the line in the yoke again.
Here is a how to link I found.
Know How Notes - How to Make a Double Flare Brake Line
Adding this because it super kool
My Tacoma Build!
https://www.tacomaworld.com/threads/...-build.391825/
EchoBase is offline   Reply With QuoteReply With Quote
Old 09-26-2016, 02:45 PM #30
huvgti huvgti is offline
huvgti is on a distinguished road
Help
Apologies for digging up an old thread. Unfortunately, I just joined and it won't let me post a new thread until I get enough replies posted.
I need help figuring out how the front brake line mounts to what I think is the spindle. I bought the truck used and it's zip tied currently. I'd like to get new hardware and correct this.
I've got a picture below. If anyone has a clear picture of how this mounts, that would help a lot. I can't seem to find a straight on shot and I've search google pretty deeply.
There are unidentifiable clips that I can buy on the toyota parts websites, but none mention the hardware, if it's a bolt and nut or what.
Any help is very much appreciated.
huvgti is offline   Reply With QuoteReply With Quote
Hard to find Specs, Info & Measurements on 231mm 13WL Tundra Calipers & Rotors BigFishAllDay 3rd gen T4Rs 1218 07-11-2023 11:04 AM
WTB: Rear axle hard brake line 3rd gen J-money$$$ Want to Buy/Trade 4 11-12-2015 06:46 PM
WTB 1990 3vze A/c Hard Line bagelsjustbagels Want to Buy/Trade 0 08-05-2013 01:21 PM
Pinched hard rear brake line. Ideas? J-money$$$ 3rd gen T4Rs 8 05-28-2011 12:05 PM
hard line needed when doing tundra brakes freshley 3rd gen T4Rs 3 10-29-2010 09:54 PM
