Originally Posted by Thorgan112
but that would make the same sound in 2wd then as wheel no?
Not if its a U joint from the front drive shaft, then when in 2WD the transfer case won't have power going to it. If there is slop in the joint then when you hit the gas the one side of the drive shaft accelerated and then slammed into the otherside making it clunk. If its in 2WD no power is being applied to make it clunk.
I don't know if that's the case, seems possible. Maybe someone else can confirm or deny.
