Old 08-14-2013, 11:47 AM #1
lhsoulrebel's Avatar
lhsoulrebel lhsoulrebel is offline
lhsoulrebel is on a distinguished road
Bump stops
At the risk of being "e" yelled at...
( I did do a search, but didn't find what I was looking for)
So, I'm looking for some info on maximizing my rear flex on the toytec ultimate lift. Anyone running this lift mess with the bump stops? I have stock 99 stops in both the springs and on the frame... I have heard of some guys cutting the spring stops down a bit, and getting longer frame stops.... Will this help with rear axle flex? (part one)
My second question is that I am considering getting the super flex springs from toytec, as im getting the savage rear bumper with swing out, and worried about sag...... Will I need to do anything else... I have the bilstien res shocks (5125 maybe?)
Thanks in advance
Black 99 highlander. toytec ultimate lift with bilstiens, and diff drop. 255 85 BFG KM2's, and tundra 231mm brake mod to stop them. ISR, and deckplate mod, rear diff breather. Front ARB locker and compressor. Scan gauge 2. Yakima mega warrior. Savage rear with swing out. AND NOW....SC'D!!
lhsoulrebel is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 02:19 PM #2
YotaDan YotaDan is offline
YotaDan is on a distinguished road
You can shorten the bumpstops, as long as you make sure they still come in contact before the shocks bottom out.
YotaDan
YotaDan is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 02:44 PM #3
Yeah, I guess I'm looking for someone who has my set up, who can tell me if I can shorten them, and if it will help with flex at all??
Old 08-14-2013, 02:46 PM #4
tre9er's Avatar
tre9er tre9er is offline
Real Name: Tre
tre9er is on a distinguished road
tre9er's Avatar
Real Name: Tre
stock shocks are around 12" compressed, give or take a little, IIRC. So measure from the lower spring perch upwards and see how much you have. You need bump stop contact prior to the 12", obviously. You should also extend your frame bump stops to help prevent harsh bottoming.
'02 Brilliant Silver SR5 4WD Auto - 13WL TBU, Trans Cooler, Trac Off Andymod 2.0, pre-99 front bumper, more to come
Totally teh kewlest build thred
tre9er is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 03:21 PM #5
98_4runnerSR5 98_4runnerSR5 is offline
98_4runnerSR5 is on a distinguished road
While this may be true, with the Toytec Ultimate Lift kit I WOULDN'T shorten your bump stops. I ran the ultimate for the past 2 years with OME 891's and bilstein 5150's in the rear with stock bump stops. Well, about 6 months ago I bottomed out the shock on the drivers side and bent it pretty bad. 2 weeks later the passenger's side followed and did the same. Bump Stops are their for a reason and by shortening them, you're doing the opposite of what most guys do and recommend. If anything you want to lengthen them.
My rear set up is now Toytec Super Flex Coils w/ LC shocks off a 98 and sonoran steel extended bump stops. Man am I happy with the results! Way more travel and it rides great. Definitely recommend.
98_4runnerSR5 is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 03:25 PM #6
That is why it is important to test out the suspension flex. Especially when installing longer than stock shocks.
YotaDan
Old 08-14-2013, 03:35 PM #7
white_n_slow's Avatar
white_n_slow white_n_slow is offline
white_n_slow is on a distinguished road
I don't think shortening the bumpstops will give you any usable flex at all. If anything, I would go as far as to say stock bumpstops are inadequate for your application. I have extended bump stops (SS 1.2) and can still flex to the point that the spring on the drooped side is ready to fall off the truck and the tire on the squish side is wedged into the quarter panel.
I see the idea you're going after, but in practice, I don't think its going to do you any good.
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
white_n_slow is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 04:33 PM #8
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
If you want more flex get the superflex coils or LC coils, then lengthen stops to eliminate over compression.
JayRolla is offline   Reply With QuoteReply With Quote
Old 08-14-2013, 10:38 PM #9
Well, thanks for all the info guys.... I think I will go ahead and get the super flex coils... Looks like I'll have to mess with the set up the hard but fun way.... Find some obstacle and flex the f out of it. My thoughts were to shorten the spring cone stops, and get longer frame mounted bump stops... I'll double check, but it sounds like I'll need the longer shocks for the super flex coils... I'm running the 5150s right now I believe (bistien rez shocks)
Old 08-14-2013, 11:36 PM #10
If you're going with the super flex coils, go ahead and get some Toyota LC rear shocks while your at it off a 98. They're a little pricey but it's been the best set up for me and another guy I know... If you swap them out sooner than later, you can probably still sell your 5150's while they're in good shape. Pulling the super flex coils in with the 5150's will end in an over extended and buster rear shock if you do any sort of moderate wheeling....
Extended bump stops? ebg18t 4th Gen T4Rs 2 01-26-2013 02:27 PM
Bump Stops for 94 4x4 rrands1 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-15-2011 11:09 PM
Do I need new bump stops or UCA's masson74 3rd gen T4Rs 11 09-22-2011 11:26 PM
Rear Bump stops Singtoe 3rd gen T4Rs 1 03-06-2011 10:15 PM
Bump Stops (Daystar 2.5/1.5) DonnyB 4th Gen T4Rs 11 09-26-2010 03:05 AM
