Old 08-15-2013, 01:58 AM #1
crespoh69 crespoh69 is offline
crespoh69 is on a distinguished road
P0305 Cylinder 5 Misfire
Hello everyone, I'm hoping someone will be able to help me fix this issue I've been trying to fix. I've changed the plugs, the wires and have even swapped the #5 coil pack with the #3 coil pack to see if the code moves but the same code still comes up and the car will occasionally run rough. What's the next step I can take?
This is for a 99 Auto 6 cyl
crespoh69 is offline   Reply With QuoteReply With Quote
Old 08-16-2013, 01:53 AM #2
Originally Posted by Kanger328 View Post
Ahhh, I've been battling this for the past few months only my misfire is on #3.
Next, try swapping fuel injectors to see if the misfire moves. I did, but hasn't fixed the problem. If that doesn't work, try replacing O2 sensors (advice I received from this forum and most likely my next step). If these don't work, then...
...you may have a blown head gasket or cracked head. Symptom would be loss of coolant and/or coolant smell/white smoke from exhaust when starting the engine after it has been sitting for awhile. Pray this isn't the issue.
Word of Advice: Don't get too excited if the engine starts running well right after completing one of these steps. My engine ran well for a few weeks after each step I took: plugs, wires, coil pack swap, fuel injector swap. But, inevitably, the daggone misfire came back. Good luck to us both.
You know what I will try the O2 route as well because a few months prior to this I was also getting an O2 code but forget what it was exactly, it went away on it's own.
Old 10-21-2021, 07:30 PM #3
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I really hate to bump an ancient thread but cylinder #5 hasn't been very nice to me lately and its been troubling to diagnose the problem - new spark plug and coil pack made it in there but it did not fix the misfire. By throwing in Seafoam injector cleaner in the gas tank and pushing it hard, the stuttering did lessen a bit and its not as bad as before but its still doing it intermittently. I'm concluding injector #5 is failing.
I heard that aftermarket fuel injectors are junk. Would you guys recommend replacing or rebuilding the injector? For now, i'm going to throw in some more fuel injector cleaner and see if it helps it a bit more.
2000 4Runner Limited 4x4 V6
Old 10-21-2021, 08:23 PM #4
spartacus's Avatar
spartacus's Avatar
Replacement injector with an oem injector. I had issues with a refurbished injectors. Some say motorwest performance injectors are good but I don't know if they sell one. Normally it's a set of 6 or 4.
Old 10-21-2021, 09:14 PM #5
Hmm, i'll have to look deeper into this. Thanks for the advice. All I heard from Motorwest is that they will just clean them.
Old 10-21-2021, 09:24 PM #6
spartacus's Avatar
spartacus's Avatar
I am fairly sure they sell em. Check their site motorwestperformance.com.
if you want to get them cleaned and refurbished this guy in Colorado is the best imo.
Home
Misfire cylinder 4... Jeff T 4th Gen T4Rs 30 03-11-2013 07:51 AM
P0305 Misfire on Cylinder 5 Please help! jnymdnyt 3rd gen T4Rs 1 03-04-2013 05:40 PM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
Cylinder 2 misfire... joneseyyy 5th gen T4Rs 5 08-05-2011 11:42 PM
Cylinder 1 Misfire... Please HELP!!! CJ4R 3rd gen T4Rs 3 09-04-2010 08:33 PM
