08-17-2013, 07:59 AM
Real Name: Trevor
Real Name: Trevor
Question about the total chaos UCAs
Does this replace the balljoints? I was confused because it says it does but it's an upper control arm and the ball joints are the lower ball joints.
98 4Runner V8 tundra swapped 'Lucky' This that and another. My build http://www.toyota-4runner.org/3rd-ge...ld-thread.html
"I say it all the time, my truck is a hybrid damnit, it goes on and off road."
08-17-2013, 08:24 AM
There are upper and lower ball joints!
08-17-2013, 08:25 AM
It replaces upper ball joints.
17 Jayco Precept 35UP Motorhome - 18 Jeep Wrangler JLU - current
16 4Runner TEP KDSS - 15 4Runner Trail KDSS 4x4 - 06 4Runner V8 4x4 - ALL SOLD
97 4Runner Ltd. 4x4 - SOLD - http://www.toyota-4runner.org/3rd-ge...d-project.html
08-17-2013, 08:30 AM
Real Name: Trevor
Real Name: Trevor
That's what I thought, what can I do to beef up the lower balljoints?
08-17-2013, 08:33 AM
Real Name: Trevor
Real Name: Trevor
I realized I worded that wrong haha. My bad.
08-17-2013, 08:53 AM
I don't know if its beefed up, but the PO of my 4runner put Tacoma LBJ on which seem to be pretty good.
08-17-2013, 09:01 AM
Real Name: Trevor
Real Name: Trevor
I see, sounds good
08-17-2013, 09:12 AM
Real Name: Casey
Real Name: Casey
The Tacoma LBJ is the same size, and prone to the same failure. The only difference is the outer tie rod is slightly larger and you lose turning radius.
'98 4runner | SAS'd | Locked F/R | Armored | Supercharged | URD Goodies |
My Build Thread
08-17-2013, 09:39 AM
Real Name: Trevor
Real Name: Trevor
Now that I think about it, I've seen a newer Tacoma surcome to LBJ failure. I was leaving base and bam the tire popped out from under this tacos driver side. No one was hurt but the mans pride.
08-17-2013, 09:49 AM
Real Name: Casey
Real Name: Casey
Second gen Tacoma's as well as any 120 platform have much stronger front ends. The CV joints are almost double the size, and the ball joint design is much stronger and safer
My Build Thread
08-17-2013, 11:10 AM
Absolutely correct. My turning radius sucks! I don't recommend the Tacoma LBJ. I'm still learning/figuring out what has been modified on mine. Whenever possible I try to replace with OEM parts. Thanks for the correction to my comment!
08-17-2013, 11:25 AM
Real Name: Trevor
Real Name: Trevor
Yeah I am doing the same with mine, well was doing the same with mine. The PO had some cheapie parts. Also, yes I've been working all day so I'm a little bit scatter brained haha.
08-17-2013, 12:34 PM
Real Name: Instagram: briansd_97r
Lots of LBJ threads on here but you won't see them unless you do a Google search (my Sig) because LBJ like TRD has only 3 characters.
Anyways ... Stick with OEM, avoid Moog like the Plague.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
08-17-2013, 12:48 PM
Real Name: Trevor
Real Name: Trevor
Moog...never heard good things about them before I had a Runner. OEM would be stuff like AC Delco and JDM right?
08-17-2013, 02:22 PM
Real Name: Nathan
Real Name: Nathan
No, OEM would be Toyota. Go to your local dealership when you get off that boat/sub and order them there or go through a Toyota dealership online to save some money.
Sold the 3rd Gen, someone totaled my 4th Gen. Sold the LT'd Tacoma. Finally got my FZJ80!
