08-21-2013, 12:44 PM
Real Name: Mason
Real Name: Mason
How long has your manual clutch lasted?
How long has your 5-speed clutch lasted for? I ask this as I bought my 98 4runner from the original owner at 168k two years ago. I asked if the clutch had ever been replaced and he said no. The rig had never really been put into 4x4 either unless there was snow (maybe 1-2 times a year) and I guess his wife was pretty good at driving the 5speed. Now my 4runner has 194k and the clutch still seems to be strong. I became a little worried a few weekends ago when I smelled something while rig was descending and engine under load (back window was down though). Today I just tested the clutch flooring the rig on the on ramp and seeing if the RPMs would ping. RPMs all the way up to 5000 (2nd and 3rd) and smooth RPM climb and speed increase so I guess I'm in the clear? Don't really know of other ways to test the clutch.
In about a week I will be driving 8 hrs to get into the SW Colorado for some offroading. Three days of it so just don't want my clutch going out while up there.
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
08-21-2013, 12:49 PM
Real Name: Kyle
Real Name: Kyle
I've got 225k so far on the original clutch and it feels and grabs just fine still.
Pictures of my Junk
08-21-2013, 12:56 PM
If you tow heavy load as little as 70k-100k
If you don't tow and have good driving habits over 200k
When to change clutch is when the first stages of slippage occurs.
08-21-2013, 02:12 PM
Mine was changed around 160-165k. I wouldn't change it unless your truck has given you reason to doubt the clutch (slipping). If you abuse your clutch it will make a smell (smells a little like burning brakes), but that doesn't mean your clutch is done for... just means you may have shortened the life a little. Sometimes the situation requires you abuse the clutch a little (climbing a ledge, for instance).
Both my FJ60 and my mini truck saw a lot of abuse off road and both had original clutches well past 200k. I'm not sure why the PO replaced the clutch on mine, but judging by the noises the transmission makes, I think he may have used the truck for towing.
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
08-21-2013, 07:13 PM
Real Name: Mason
Real Name: Mason
Cool,
Thanks guys. Thinking I'm cleared for a major 4x4 weekend. white_n_slow, what kind of noise does your trans make that makes you think that?
08-21-2013, 10:27 PM
The PO of my 97 replaced the clutch just before selling at 210k
97 T4R SR5 4x4...mods to come later
2011 T4R SR5....Wife's daily driver
08-21-2013, 10:28 PM
It sounds like your clutch is good to go. My Runner supposedly has a new clutch in it but it feels really soft to me. I managed to warm up the clutch last time I was out wheeling, but I'm also turning 33" tires on stock gears. You should be fine on this trip. I think it would be worth your time to replace it in the near future. Use a decent clutch and she'll probably last for life of the truck.
08-21-2013, 11:02 PM
No reason to worry, but testing a clutch under low load isn't the way to do it.
You actually cause more load by going to a taller gear and going WOT. This puts more strain on the clutch then the proper gear at WOT.
Mine has 260KM and still seems to work fine. I know the day is coming, but sounds like it may be a long time yet!
'98 Desert Dune SR5 - 5-speed, sunroof, e-locker.
TRD/LC lift with Bilstien 5100 and Factory LC Rears
Currently 325,000KM's.
08-21-2013, 11:26 PM
I'm a new owner too, and my 2000 has 120k and the clutch was 'stiff', it would grab hard and would easily kill the engine. I know, sounds like I don't know how to drive a stick, my first car was a stick, no prob here.
I too am planning a long term trip and wanted to make some routine repairs and upgrades. The guy I bought from was original owner and kept meticulous records and never changed the clutch, but I don't think he was good to it.
Anyway, long of the short is, once I changed the clutch about a week ago, it felt REALLY soft, but now I can engage first w/o even using the gas. To me that's a first, but way different than a 'biting' 'stiff' engagement. I think it was burned up, and that's usually the worst, unless you've hit the rivets and are gouging the plate/flywheel, and you will hear that.
I would say you're GTG....
Also, I am extremely happy to hear that these clutches last so long! I would hate to have to do that too often...
Reason: additional comment
08-21-2013, 11:28 PM
Well, newer owner than you...
12-04-2017, 08:44 PM
I have 201k miles on my 98 4Runner and am still on the original clutch. It seems fine to me, especially after my mechanic replaced a leaking hose. Pedal is now biting notably higher. It is not slipping, making noises or anything. Mechanic recommended replacing it saying it was "wearing" but I am leaning against doing so. I am the original owner and since I now have another vehicle, I only drive it 3k to 4k miles a year and I've been religious about regular service. The only thing that would press me to replace it is if it were to go out during winter. I count on it to get me through big (multi-feet) snow storms.
12-04-2017, 09:49 PM
Real Name: Scramble
Real Name: Scramble
The only reason I replaced mine @ 143k was because the engine was out. My mechanic said he'd install it for free so I bought a Marlin HD clutch & flywheel. The old clutch still had some meat on it but better to do it then than pay him $900 2 years later down the road was my thinking. Now I'd do it myself if I had to.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
12-04-2017, 09:57 PM
Real Name: Throws like a girl
'96's throwout bearing around 210,000, did clutch kit at the same time for obvious reasons.
Husband's '99 clutch at around 210,000 too.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
12-04-2017, 10:11 PM
225K (approx).........replaced with a Marlin Crawler HD 1200lb kit.
1997 T4R SR5 3.4L 5 speed with factory e-locker bought new with almost 1km on it
12-04-2017, 10:20 PM
PO changed the clutch at 213K.
I plan to upgrade to a Marlin 1200lb when the clutch goes, or when I'm in there because of "other" repairs.
