Old 08-31-2016, 09:12 AM #16
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
Originally Posted by RikTT View Post
Bit of a revival here specifically to 01/02 4wd Trans...
Does the SR5 4wd and 4wd trans use the same ECU ? 2001-2002
Installed a '02 used 4WD trans into a '02 SR5 4WD Sport ED and the shift from 1st to 2nd is stretching to about 3100 rpm, any throttle. Reverse is delayed, sometimes it has to rev like a manual to move back. Fine is all other gears
Any insight will be helpful
I completely agree with above post. Slipping into reverse and late shifting are never good signs. All autos I've felt do this ended up completely failing eventually.
JayRolla is offline   Reply With QuoteReply With Quote
Old 08-31-2016, 10:04 AM #17
frodiesel's Avatar
frodiesel frodiesel is offline
frodiesel is on a distinguished road
frodiesel's Avatar
Originally Posted by Bryan1 View Post
Im in the process of swapping in a new to me used tranny. The new one had its kickdown cable cut when it was removed from the truck. I cant seem to separate the kickdown cable from inside the valve body. I tried prying to get the pin out but I ended up breaking a small piece off and decided to stop before I do any more damage. Does anyone know how to remove the kickdown from the valve body?
Not sure if you solved your problem but the kickdown cable is easily accessible with the trans pan removed. I dont think it can be removed otherwise without damage. It is common practice to cut the cable when pulling at a yard.
frodiesel is offline   Reply With QuoteReply With Quote
Old 08-31-2016, 05:43 PM #18
RikTT RikTT is offline
RikTT is on a distinguished road
Pretty much figured bad trans. Was hoping for any last resort checks before I yank it out.
Between the late reverse engagement and delayed 1-2 hardshift I kinda lost hope on trans itself.
I did add a b&m oil cooler and new rad (bypass) on the install but back to trans hunting again
-ToyotaHolic-
MK4 Supra 6spd x 2
'02 SR5 SE 4R
RikTT is offline   Reply With QuoteReply With Quote
Old 10-30-2016, 05:29 PM #19
pcr777 pcr777 is offline
pcr777 is on a distinguished road
Are the solenoids able to be replaced? My son has a 2001 2WD 4 Runner with the tranny stuck in some higher gear. He limped it into a parts store. They read a fault code saying faulty transmission solenoid. A solenoid change-out would be relatively easy and affordable. Any insight is appreciated.
pcr777 is offline   Reply With QuoteReply With Quote
Old 09-29-2017, 08:18 AM #20
68ChargerJMP's Avatar
68ChargerJMP 68ChargerJMP is offline
68ChargerJMP is on a distinguished road
Fwiw.....I just installed a transmission from a 99 Limited into my 97 Limited. I had to use the transfer case from the 97 but it all seems to be doing fine.
1997 4Runner Limited: Elocker, OME 880/906/5100, 231 Tundra brakes, 265/75/16 Falken AT3W on Pro Comp 7069s
68ChargerJMP is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 09:54 PM #21
Banjo Banjo is offline
Banjo is on a distinguished road
Thanks. This gives me hope. I just picked up a 98 with a 00 engine and transmission. The transmission works fine but the theres no front driveshaft so I dont how the 4x4 does yet. The 98 is sr5 and the 00 transmission is limited... so I dont what issues I may run into with that as well. I'm looking into replacing my wiring harness because the one on it now looks rigged and very unprofessional.
Banjo is offline   Reply With QuoteReply With Quote
2001 , 4runner , 4wd , a340f , transmission
A340F transmission needed White 4x4runner 3rd gen T4Rs 15 05-10-2013 04:35 PM
A340F Valve Body Jagerzel For Sale: T4R Items 0 03-25-2013 03:50 AM
A340F / AW4 Valve Body Jagerzel For Sale: T4R Items 4 04-04-2012 10:28 AM
A340F transmission quirks RescueMonkey 3rd gen T4Rs 1 01-06-2011 11:23 AM
Need A340F transmission 3rd gen Kevs442 Classifieds - buy & sell (no commercial ads please) 0 09-02-2010 10:38 PM
