Old 08-22-2013, 04:13 PM #1
Mynameistommy510's Avatar
Mynameistommy510 Mynameistommy510 is offline
Mynameistommy510 is on a distinguished road
2000-02 A340F vs pre-00
I picked up a 2001 sr5 transmission including transfer case off Craigslist for $350 a while back. Only problem is, I drive a 1996 sr5 4runner. The easy solution would be trade it for an older model transmission. Before I do that I'd like to consider a few other options.
If you don't know, the earlier models have a kickdown cable. The later models have an electronically controlled kick down. So would I be able to swap these two assemblies?
What would be another solution?
I realize this is an odd idea, but I'm not totally convinced my money was wasted.
Mynameistommy510 is offline   Reply With QuoteReply With Quote
Old 08-22-2013, 09:35 PM #2
BigFishAllDay's Avatar
BigFishAllDay BigFishAllDay is offline
BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about
Welcome to the forum, Tommy. Here's your answer:
The compatibility issue lies not with the transmission, but with the valve body, which is essentially the "brain" of the transmission. Much of the information below is a re-post from a writeup in my build thread.
The early model years (1996-1998?) used a VB like the one below. Notice the overall length, which is shorter than the later versions, and the presence of the tubes (there should be two tubes, one has been removed in this photo) on the left hand side. The tubes are transmission fluid paths that were integrated into the actual VB on later versions. Also note the connection for the transmission kick-down cable @ bottom center. The other end of that cable connects to the throttle body and controls line pressure in the transmission @ various throttle positions. Last, notice that there are only three electronically controlled shift solenoids. Two along one edge and the third at the end near the tube.
The mid generation model years (1998-2000?) used a VB like the one below. Notice the increase in overall length, and that the VB now encompasses the fluid paths that were previously separate tubes. Also, notice that there is still a connection for the transmission kick-down cable to control transmission line pressure. Finally, there are still three electronically controlled shift solenoids, but their position on the VB has changed. All three solenoids are now aligned on one side of the VB.
Last but not least you have the late model VB (I know for sure this one is found on 2001-2002 model years). This version retains the overall shape and size of the previous version, but there are changes to the hydraulic controls. Where line pressure was controlled manually by a kick-down cable on prior versions, it is now controlled electronically by the ECU using a 4th solenoid, the SLT solenoid. This goes hand in hand with the drive-by-wire feature found on the 01-02 models. Take a peek under the hood of a ’01-’02 and you’ll notice that there is only one cable connected to the throttle body, which is a failsafe throttle cable. The transmission kick-down cable is eliminated on these model years. This version also gets a 5th solenoid, which is the Shift Control Solenoid, however it is not electronically controlled. The two new solenoids are visible at bottom center, where the cam and kick down cable were located on previous models.
You will not be able to install the transmission from the '01 into your '96, due to the presence of the SLT solenoid on the '01 transmission valve body (and the corresponding lack of provisions for a kickdown cable), which the ECU on your '96 will have no means of controlling. Also, you will not be able to install the valve body from the '96 transmision into the '01 transmission because the fluid paths are laid out differently, due to the '96 valve body having the separate tubes, as pictured above.
You need to get your hands on a transmission that came from a similar model year 4Runner ('96-'98) that has the same type of valve body and provisions for a kickdown cable. The only other potential solution would be to pick up a transmission from one of the mid-gen model years, which also have the provisions for the kickdown cable, along with the updated valve body. However, I'm not even sure that would work because there maybe be differences between the solenoids on the two versions of the valve body that would result in compatibility issues with the ECU.
Hope that helps.
2001 SR5 Sport Ed. S/C'd V6 Auto 4wd (< Click for Build) ....everything but a kitchen sink (it's on the "to do" list)....
2003 Tacoma SR5 S/C'd V6 5-spd 4wd (< Click for Build) ....boost, armor, lockers, gears, etc....
2008 Sport Ed V6 Auto 4WD (< Click for Build) ....the Grocery Getter OEM+ build....
My Write ups: T-Case Leak? - 231mm TBU - Rear Axle Seals - Trans. Cooler Install - Suped Up Air Comp - Big 3
BigFishAllDay is offline   Reply With QuoteReply With Quote
Old 08-22-2013, 09:55 PM #3
afg10000's Avatar
afg10000 afg10000 is offline
afg10000 is on a distinguished road
afg10000's Avatar
Damn, BigFish, that's a thorough response. That's awesome info. That's why this forum is so helpful. Cheers to ya -
'96 Limited - Locker - 127k- totaled out -
'01 Limited 175k - sunken and resurrected - stock, other than TBU 231mm
'98 Limited - Locker -158k-Bilstein 5100 Tacos- Toytec/Eibach 3" lift coils- diff drop-265/75/16 Duratracs -OME 890's-Bilstein 5125's, panhard bar drop, TBU 231mm, Spidertrax 1.25' spacers, Savage sliders, 2nd gen SC/URD 7th, JBA exhaust, HID retrofits -
afg10000 is offline   Reply With QuoteReply With Quote
Old 08-27-2013, 02:58 PM #4
BlueMountainRunner BlueMountainRunner is offline
BlueMountainRunner is on a distinguished road
Has anyone figured out if this would work? I have a 2000 and want to install a 1998 trans in it.
BlueMountainRunner is offline   Reply With QuoteReply With Quote
Old 08-27-2013, 04:10 PM #5
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Also noteworthy for future CL buys that a 2-5 minute phone call to your dealership parts department would have told you a simple yes/no on compatibility.
Great info though BFAD. I read about the VB differences in your build thread and even after such a detailed explanation I'm still a bit baffled by it all.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 08-28-2013, 12:39 PM #6
Good, practical advice for the uninformed among us. That's the first place I would have looked for reliable info, rather than posting on a forum.
I love how Mr. Mynameistommy510 never even followed up on this thread... which is a perfect example of why I normally don't respond to random question threads posted by new members.
Old 02-09-2015, 06:45 PM #7
I fixed my notifications and have become more active on the forum. Luckily the seller of the transmission knew about as much as I did about the A340f, this transmission has a mount for a kickdown cable indicating its from an earlier model 4Runner.
Your information was not wasted! A Google search led me back to this old post, and I hope it helped other people in choosing a replacement transmission. Thank you for your extensive and helpful post BigFish
Old 03-11-2015, 06:43 PM #8
oneal48's Avatar
oneal48 oneal48 is offline
Real Name: Jerry
oneal48 is on a distinguished road
oneal48's Avatar
Real Name: Jerry
So I have a 2001 and I found a 2000 transmission. Will this not work in my truck. Both are 4x4 from a 3.4l engine. I understand the transfer case is different but is the transmission also different to the point this can not be done?
2001 SR5 4Runner 4X4- Toytec Front Coils with Billy5100 first perch. Rough Country rear coils. Home made "scrap metal" front bumper with 8000lb winch.
Sold- 1995 4Runner 4X4
Sold- 1993 3.0 5Speed Locked Pickup
oneal48 is offline   Reply With QuoteReply With Quote
Old 04-16-2015, 10:49 PM #9
natesbox's Avatar
natesbox natesbox is offline
natesbox is on a distinguished road
natesbox's Avatar
oneal48 - From reading this thread it sounds like you need the electronic kickdown version. I have a 2000 and and am looking for the trans you have! heh
I wonder if the tundra a340f like this one Automatic Transmission Toyota Sequoia 2003 03 2004 04 4x4 693787 | eBay would work for you if you could switch valve bodies. Ive been reading and it seems that the tailpiece and the transfer cases are interchangeable. I wonder if the bellhousing is as well.
did many searches, Need clarification On A340f Transmissions - Tacoma World Forums
natesbox is offline   Reply With QuoteReply With Quote
Old 04-16-2015, 11:15 PM #10
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Since the kickdown is electronically controlled wouldn't there be a need for the trans ecu and the main ecu also?
Old 10-24-2015, 07:42 AM #11
eglide eglide is offline
eglide is on a distinguished road
trans type
could someone tell me how to identify what auto trans I have? 2000 4runner limited...thanks.....
eglide is offline   Reply With QuoteReply With Quote
Old 11-17-2015, 06:24 PM #12
Bryan1's Avatar
Bryan1 Bryan1 is offline
Bryan1 is on a distinguished road
Bryan1's Avatar
Im in the process of swapping in a new to me used tranny. The new one had its kickdown cable cut when it was removed from the truck. I cant seem to separate the kickdown cable from inside the valve body. I tried prying to get the pin out but I ended up breaking a small piece off and decided to stop before I do any more damage. Does anyone know how to remove the kickdown from the valve body?
Bryan1 is offline   Reply With QuoteReply With Quote
Old 08-25-2016, 09:02 PM #13
abishoff abishoff is offline
abishoff is on a distinguished road
I swapped the valve body and that worked fine.
abishoff is offline   Reply With QuoteReply With Quote
Old 08-31-2016, 12:27 AM #14
RikTT RikTT is offline
RikTT is on a distinguished road
Bit of a revival here specifically to 01/02 4wd Trans...
Does the SR5 4wd and 4wd trans use the same ECU ? 2001-2002
Installed a '02 used 4WD trans into a '02 SR5 4WD Sport ED and the shift from 1st to 2nd is stretching to about 3100 rpm, any throttle. Reverse is delayed, sometimes it has to rev like a manual to move back. Fine is all other gears
Any insight will be helpful
-ToyotaHolic-
MK4 Supra 6spd x 2
'02 SR5 SE 4R
RikTT is offline   Reply With QuoteReply With Quote
Old 08-31-2016, 08:46 AM #15
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Reverse slow to engage is usually a problem with seals. The piston to engage is not pushed because the cylinder is leaking, especially when cold. Shifting out of second could also be line pressure, although controlled electronically, it still has to have good enough sealing to work correctly. I'm not a transmission guy, but it sounds like you got a bad trans there.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
2001 , 4runner , 4wd , a340f , transmission
A340F transmission needed White 4x4runner 3rd gen T4Rs 15 05-10-2013 04:35 PM
A340F Valve Body Jagerzel For Sale: T4R Items 0 03-25-2013 03:50 AM
A340F / AW4 Valve Body Jagerzel For Sale: T4R Items 4 04-04-2012 10:28 AM
A340F transmission quirks RescueMonkey 3rd gen T4Rs 1 01-06-2011 11:23 AM
Need A340F transmission 3rd gen Kevs442 Classifieds - buy & sell (no commercial ads please) 0 09-02-2010 10:38 PM
