06-10-2020, 09:27 AM
#211
Real Name: Patrick
Real Name: Patrick
Originally Posted by Mark_BC
It's from your lift, if you haven't done a diff drop. It puts them at suboptimal angles.
How would a diff drop change anything with the lower ball joints?
08-05-2020, 02:49 PM
#212
LBJ bolts 2001
I’m ordering parts to the LBJ’s on my 2001. I’m confused about the correct Part number or the four bolts Per side to order for my ‘01?
08-05-2020, 03:42 PM
#213
Real Name: Eddie
Real Name: Eddie
What are you confused about?
Give the dealer your VIN and let them figure it out.
The LBJs are attached via the 4 bolts. Order 8 of those.
Good luck,
Eddie
2001 T4R SR5 - 180k miles and counting.
09-18-2020, 01:08 AM
#214
Real Name: Devan
Real Name: Devan
So I was aiming to do my ball joints soon (both sets), and I was curious - is it worth replacing the LCA's while I'm at it? Thinking about shooting for a new set of UCAs altogether, and I'm still rocking OEM units all around at nearly 300k
Started with just doing LBJs, then I figured I might as well snag some longer travelling UCAs, now I'm wondering if the lowers should be serviced while I'm at it - and if so, who to shop through
09-18-2020, 02:16 AM
#215
Could just replace the bushings. Bushings are the least expensive route and there are a few different methods of doing it. Solo motor sports has a pretty sweet LCA setup, a bit on the expensive side though. Could also just go oem new LCAs at 200$ each..
11-26-2020, 06:22 PM
#216
Originally Posted by Map0692
I wanted to add my experience here....
... 1998 SR5 with 192,000
.... 2.5 weeks after buying it, the Lower Ball Joint Failed.
Symptoms were only noticeable for maybe 15 miles before it gave out....
Thanks for sharing. Looks like socket lip gave way and ball pulled out?
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
09-21-2021, 10:44 PM
#217
just bought a 2002 with about 200k miles. would it be advisable to change the LBJ ?
is there a way to tell if they have already been replaced ?
is it just the front 2 or all 4 should be replaced ?
thanks
09-22-2021, 08:55 AM
#218
Real Name: Patrick
Real Name: Patrick
thanks
If there is no maintenance history on when the lower ball joints have been replaced I would err om the side of caution and replace with OEM. Before you purchase new lower ball joints see if the recall to replace them has been performed. You may be able to get them replaced by Toyota for free if the recall is still open.
EDIT: There is an inspection procedure in the factory service manual, but the specification is so small it requires the use of a dial indicator to determine.
09-22-2021, 10:06 AM
#219
Went over to Lookup Safety Recalls & Service Campaigns
and "There are no open Safety Recalls or Service Campaigns for this vehicle."
does this mean I should still err on the side of caution and get them replaced ?
EDIT: my carfax on the vehicle says nothing about a LBJ
are only the front LBJ the ones to be replaced ?
09-22-2021, 12:09 PM
#220
Real Name: Patrick
Real Name: Patrick
Like I said earlier, if you don't know when they were replaced last I would replace them. Only the front end has lower and upper ball joints.
09-27-2021, 05:38 PM
#221
So I am about to change the LBJ this weekend and noticed there are no nuts that came with the bolts.
The car has the original LBJ so are riveted.
are there no nuts ? does the bolt just screw into the brace or/and are you supposed to use loctite ?
thanks.
09-27-2021, 05:46 PM
#222
Real Name: Patrick
Real Name: Patrick
thanks.
What is the year, make, model of what you are working on?
What part numbers did you order/receive for the lower ball joints and lower ball joint bolts?
09-27-2021, 05:48 PM
#223
thanks.
The spindle has threaded holes, no nuts required.. some ppl use loctite, I can’t remember what the FSM says but I don’t use loctite I just torque to spec. Watch Timmy the Toolmans video if you haven’t already..
09-28-2021, 10:05 AM
#224
2002 limited T4R
Bolts: 90119-10933
09-28-2021, 10:06 AM
#225
Thanks, just needed that reassurance cause I didnt see any nuts in timmy's video.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
