08-30-2013, 08:34 AM
#16
Originally Posted by shootmymime
let me know if there is anything else i should add to make it better.
A couple of things.
1. A good tip of advice is to spray all the components you will be taking off (described later) with some sort of lubricating penatrating oil (wr40, PB blaster).
2. Prepare all the parts and tools you will need before you start to tackle this job if this is your only vehicle. The parts and tools I used were an impact wrench and sockets measuring 15/16, 3/4, 9/16, 13/16. A large hammer. The ball joint associated with the side your replacing. Jack and jack stands. Dykes or wire cutting pliers. another tool you might need is a torch and a pickle fork, but i did not need them.
There are no SAE size fasteners on the 4runner. You need 14mm, 17mm, 19mm, and a 22mm sockets to do the job right.
And don't use a castle nut backwards and beat off the tierod or ball joint. It will damage the threads and the nut. Just hit the side of the joint with a hammer to shock it loose. No damage to anything.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
08-30-2013, 09:02 AM
#17
Originally Posted by Singtoe
A couple of things.
I knew I would catch flack for both of those. Standard is all I have when it comes to that big.
Thanks ill change the socket sizes now I know what they are
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
08-30-2013, 09:40 AM
#18
Real Name: Trevor
Real Name: Trevor
This is a very informative thread. I will defiantly use this. I vote sticky!!!
98 4Runner V8 tundra swapped 'Lucky' This that and another. My build http://www.toyota-4runner.org/3rd-ge...ld-thread.html
"I say it all the time, my truck is a hybrid damnit, it goes on and off road."
09-02-2013, 02:57 AM
#19
Real Name: Alex
Real Name: Alex
Very nice write up, think I can add to this when time permits, considering most of my front end is factory tacoma...
09-02-2013, 10:43 AM
#20
Definitely post torque specs, extremely important when doing this job. otherwise great write up!
09-02-2013, 11:06 AM
#21
Official Lower Ball Joint Write Up Thread
Do you not see them? They are in bold on each step that you take a nut or bolt off.
09-02-2013, 01:08 PM
#22
I want to add one thing.....
I have read its a good idea to replace the bolts for the lower ball joint. I just bought them this week...$11 for all 8 (from Toyota). Cheap insurance to me. Of course,I beat on mine and try to think of this type of little stuff.
`73 Ford Courier-40’s all Toyota underneath
‘22 ORP-DD-mild build
`05 Cummins...tow pig
Sold-‘98 Runner 4Runner Build
09-02-2013, 01:12 PM
#23
Real Name: Brice
Real Name: Brice
And remember to shop around for the best prices! My local toyota stealership wanted 150 per ball joint and 20 bucks for the bolts.. Toyotapartszone was way cheaper but a little slow on the shipping..
09-02-2013, 04:53 PM
#24
My new ball joints came with 1cotter pin for the ballpoint castle nut and 4 new bolts like you are saying. So I did use the new ones.
01-07-2015, 08:29 PM
#25
Real Name: Uhhh this is my real name
much appreciated shootmm
Thanks for getting this online.
My ride is only at 130K miles but there's no sense in just hoping it will not happen.
Getting this done soon.
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
01-07-2015, 09:07 PM
#26
Real Name: Asa
Real Name: Asa
I would recommend if you replace the 4 lower bolts go with oe. 2 of the new ones fell out and the other 2 were bent and they had all been loc tighted and torqued to spec, I just put the old bolts back in and haven't run into any issues so far
96 SR5, Ghetto ISR mod, SCS Stealth 6s, 35x12.5 Toyo MTs, Bilstein 5100s/Eibach coils, B&M Transmission cooler, 1.5 Inch Fat Pat body lift, OME 851s, TJM XGS Gold series LC shocks, Satoshi grill, Rear diff breather, 167 series snorkel, Toytec rear brake line, All Pro apex Front bumper with custom hoops, Custom rear bumper with Ghetto swing out, First Gen roll bar,LED parking lights/turn signals, Hybrid model
01-07-2015, 09:17 PM
#27
I second this!
2014 4runner Trail Premium w/ KDSS - 255/80/17 St Maxx, Toytec Boss, TC UCA's, Astro Start, TRD Logos
BUILD THREAD HERE
01-08-2015, 11:02 AM
#28
Agreed, hitting threaded parts or nuts always seems to result in damage. Just a slip of the wrist can mangle the threads easily.
I am surprised that no one has brought this up, but I have had very good results from using pitman pullers on the tie rods and I'd expect the same with the LBJ stud (If you can get it on the LCA). Similarly, you could use a 3-arm puller that I'm sure would work. I found I didn't even have to hit anything with a hammer to pop them out.
Pitman pullers are typically free to rent from auto parts stores, autozone and Advance should all rent them for free (basically you buy the tool, then they refund you the total cost when you return it)
Just another option!
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
01-08-2015, 11:19 AM
#29
Real Name: Kevin
Real Name: Kevin
The pitman puller that Autozone loans is too big. OEM makes a tie rod puller with much narrower jaws that worked perfect.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
01-08-2015, 11:40 AM
#30
Good to know. I think I rented mine from O'Reilly's actually. IIRC they rent out OEM, so maybe that's why it worked for me.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
