Originally Posted by hrt4me
I have a 1996 SR5 5-speed with e-locker...
your in luck as my password and login works from my home computer. Here is basic radio and alarm info for the 96 T4R. They do not designate different trim as SR5 and limited are wired essentially the same.
Being yours is stick, remote start is not recomended because you would need to bypass the clutch to start, but all other alarm and keyless featres should work fine.
Good Luck!
Battery BLUE/YELLOW (+) RADIO HARNESS
Accessory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna BLACK/RED (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Amp Location RIGHT OF GLOVEBOX
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Security
WIRE COLOR POLARITY LOCATION
Battery WHITE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/RED (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/SLV.DO (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/WHITE (-) BACK OF FUSEBOX AT WHT 3 PIN CONN
Trunk Trigger RED/WHITE (-) DRIVER'S KICK AT WHT 26 PIN CONN
Parking Lights DARK GREEN (+) BELOW FUSEBOX AT WHT CONN
Convenience
Headlights-Lo RED (-) AT STEERING COLUMN
Trnk Release N/A
Remote Start
Accessory 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS (TESTS AS IGN.)
Anti-Theft Descript NONE
Tachometer BLACK (-) AT IGNITOR ON PASS WHEEL WELL
Speed Sense GREEN/ORANGE (AC) ECM BEH.GLOVE,22 PIN PLUG PIN 8
Brake Lights GREEN/WHITE (+) AT BRAKE SWITCH
Reverse Lights RED/YELLOW (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
Horn GREEN/RED (-) AT STEERING COLUMN
Modules
WIRE LOCATION
Module 1 ECM BEHIND RIGHT SIDE OF DASH PANEL
Doorlocks/Windows
Power Unlock RED/YELLOW (-) NEGATIVE TRIGGER
PowerLock RED/WHITE (-) DRIVER'S KICK PANEL
