09-17-2013, 07:36 PM
Largest fully inflated 16" spare tire that will fit in the stock spare location?
I was wondering what the largest 16" tire is that will fit under the truck in the stock spare location without cutting and modifying the frame? Also it needs to be capable of clearing the stock trailer hitch. I am told that 33's will fit deflated, but i am interested in knowing what size will fit fully inflated.
I know stock is 265/70/16(30.6"), so maybe a 265/75/16(31.6") or 275/70/16(31.2")...does anyone know for sure? Thanks in advance!
Black Beauty-96' 4Runner 4WD Limited V6, 353k mi.
09-17-2013, 08:45 PM
I think a 265/75/16 will fit. What size are you running now? If it's a 285 just deflate it and carry a compressor to air it back up if you ever need it.
The 4Runner Show
09-17-2013, 09:26 PM
my Silent Armor 265/75/16 fits with no trouble fully inflated. I'm wondering if a 285/75/16 would fit aired down some, anybody tried that?
215k+ 1997 SR5 manual, e-locker, + stuff
09-17-2013, 10:10 PM
somebody here got that to work... I think it might have been The Kid and his Rescue Runner...
09-17-2013, 10:11 PM
Real Name: Adam
Real Name: Adam
My spare is a 265/75/16 and it's fully aired up. I still have an inch or so before it hits the hitch. You could maybe get a lower tread 285 spare with about 30 psi in it...so it still gives a little.
09-17-2013, 11:58 PM
I have the stock trailer hitch and my spare is a Treadwright 265/75/16 Guard Dog. It won't fit. The tire measures a full 32"'s though, not 31.2 etc.. Even deflated I couldn't get it to fit without jamming it against the hitch and pan hard bar. What I'm getting at is it depends on your tire and your hitch.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
09-18-2013, 01:42 AM
That's going to depend on what tire it is, as well as tread depth, and a ton of other variables, you could have 2 tires that are the same size, but from different companies, and they could be different enough that one would fit and one wouldn't.
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
09-18-2013, 01:46 AM
I'm running a 265/75/R16 and it fits perfectly. If thats any help
09-18-2013, 08:08 AM
I have a 285/75/16 BFG that has 1/4 of the tread left on it as a spare in the stock location with a stock trailer hitch on as well. I know a full tread tire that size will not work. Hope that helps.
1998 Limited Desert Dune
2.0 Sway-Away Coil-overs front, OME 906 Coils & 60028 NitroCharger shocks rear, Deck Plate Mod, K&N, 285/75R/16 BFG A/T KO's, Magnaflow exhaust, Remote start, Tinted Windows. Many more to come....
09-18-2013, 10:27 AM
Real Name: Chris
Real Name: Chris
I also have a 285/75/16 spare with 7/32 tread underneath. It measures 32". Rubs on the panhard (track bar) when flexing.
Edit: I have an OEM hitch too.
Fishwerks' Photo/Build Thread 2000 SR5 l White on White l 35s l Supercharged
2010 Trail Edition l Salsa Red Pearl l Stock
Instagram
09-18-2013, 10:30 AM
I have a fairly new 285/75 16 Revo that fits with no issues.
'98 4Runner, 35" TTCs, E-Locker, 4.88 Yukon's, 3.4L, 5-speed, 3" Susp Lift, 3" BL, Elbow mod, Deckplate Mod, "D" gasket mod, 22" Magnaflow, 231mm Tundra Brakes, 67" TG Sliders, 8500lbs Portable Winch, Airlift Bags, Magellan GPS...
My Build Thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
09-24-2013, 09:19 PM
Thanks for the replies guys. Im currently on 35's but was considering removing the 1.5" BL and dropping back down to a 33", but then was thinking it would be nice if i could fit a spare in the stock location all aired up and ready to go. Just afraid any smaller than 33" and i might be dissapointed.
09-25-2013, 02:18 PM
For temporary get-home spares, not only do I hate dragging the tire, but I hate seeing that thing hang down...
A good little spare will get you out in a pinch - consider a 235/85 or a 255/85 'doughnut' spare.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
09-25-2013, 04:23 PM
I have a 285/75/16 in the spare location. It is well worn and down to around 10 PSI but it fits nicely. No interference with the panhard bar. I carry a small compressor with me.
Steve at Sonoran Steel has a method for cutting out the factory tire winch and putting in an earlier Toyota winch (chain instead of cable). His system allows a 285/75/16 to be stored, fully inflated, in a much higher position than the factory spare. Looks really nice and uses toyota parts.
1999 4runner SR5 212k and still going
Build/Maintenance Thread
09-26-2013, 12:18 PM
Good point, i talked to Steve and he said if i cut out the crossmember and modify and reweld it that even a 35" will fit, just not sure i want to go through the hassle yet. I have a pretty cool tire carrier that i made that fits around the stock bumper im just not sure i like the spare back there as much as i thought i would.
