Originally Posted by awthorn
@ opie74
sound advice on preventing bushings from being damaged without pre-loaded; should I just leave a little play to it and use a floor jack / wood blocks to get it in the right position? Do I need to do this for the rears as well?
Thanks again everyone for the input / help!
No need for wood blocks or a jack.... Leave the upper control arm and lower control arms bolts loose. As well as the bolt that connects the strut to the lower control arm. These should be the last bolts you tighten
after you get the vehicle back on the ground and bounce the suspension a couple times.
Or were you referring to taking the strut out?
