Old 09-30-2013, 11:06 PM #1
slimatic slimatic is offline
slimatic is on a distinguished road
Intermittent Shudder While Braking
99 5spd vr6
Once in awhile when I'm braking, usually from high speeds, the vehicle shudders. I assumed this meant that I needed new brake pads.
I took a look at the passenger side today. The rear pad still has a lot of life left about a 1/4 inch, no searing, looks normal. Front disc has no scarring, brake pads are thick with a lot of life left, however the inner pad is slightly thicker than the outer. Also the inner side of the caliper looks a lot worse for wear.
I'm no expert, so I had my Dad take a look. He said everything looked good. The only thing he could think of was that the front inner brake pad side of the caliper may have seized up. Which could be the cause of the difference in front brake pad thicknesses.
Is there anything else that could cause the shudder that I should look into? Could it be the caliper?
slimatic is offline   Reply With QuoteReply With Quote
Old 09-30-2013, 11:18 PM #2
PitbullRescuer's Avatar
PitbullRescuer PitbullRescuer is offline
PitbullRescuer is on a distinguished road
Brake rotors.
'98 SR5 4x4, cheap DD http://www.toyota-4runner.org/3rd-ge...im-addict.html '99 SR5 Highlander 4x4/5 Speed... http://www.toyota-4runner.org/3rd-ge...eed-build.html '97 SR5 4x4/5 speed, another new project... http://www.toyota-4runner.org/3rd-ge...new-build.html '00 SR5 4x4, new project, stay tuned... http://www.toyota-4runner.org/3rd-ge...ld-thread.html '97 Limited 4x4, freshened up quite a bit... http://www.toyota-4runner.org/3rd-ge...d-3rd-gen.html '99 SR5 Highlander 4x4... http://www.toyota-4runner.org/3rd-ge...ce-thread.html
PitbullRescuer is offline   Reply With QuoteReply With Quote
Old 09-30-2013, 11:24 PM #3
nissanh nissanh is offline
Buy NEW rotors. Don't go for re-surface.
Old 09-30-2013, 11:31 PM #4
Originally Posted by PitbullRescuer View Post
Brake rotors.
Really? Even if there is no scarring on it at all? Would there be a visual indicator on them or is the shudder a common issue with rotors?
Old 09-30-2013, 11:38 PM #5
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
Try this, find an area where you can speed up to around 50 then stop fast to around 5. Do this about 4 times without stopping completely. Then drive around until they cool. This should rebed the pads/rotors and stop the shudder.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 09-30-2013, 11:42 PM #6
The brakes on these things are so undersized its embarrassing. So the rotors warp very easily. It's a very common issue on these trucks. Do the Tundra brake upgrade and you won't have to worry about it anymore.
Old 09-30-2013, 11:44 PM #7
Oh ya I remember hearing about the Tundra Brake upgrade. Mind providing a link to a guide?
Old 09-30-2013, 11:45 PM #8
Thanks for the pro tip, I'll try this out first.
Shudder while braking - after driving a bit. changedsoul 3rd gen T4Rs 9 02-19-2012 03:25 PM
Steering wheel shudder when braking at freeway speeds bju96 3rd gen T4Rs 4 09-09-2009 03:00 AM
Braking vibration, intermittent problem gdewet 3rd gen T4Rs 12 05-28-2009 11:02 AM
Intermittent "clunk" upon braking and release of brakes Keywesterr 4th Gen T4Rs 11 11-20-2008 12:08 PM
Steering wheel shudder when braking - New Brakes Installed kaneman23 General Discussions 6 10-30-2008 08:55 PM
