Old 10-07-2013, 12:30 AM #1
natasha69 natasha69 is offline
natasha69 is on a distinguished road
Question Fuel Consumption Problem - Help!
I just drove 2 miles and the fuel gauge dropped from a full tank down to 3/4 of a tank. I drove the car from the mechanic back to my house - he was investigating this issue but found nothing.
He pressure checked the fuel lines and the tank, but found nothing. He also checked codes but found nothing.
What could cause that much fuel to be consumed over 2 miles? There is no gasoline smell when I drive it onto my driveway. I cannot see any stains/spills/etc anywhere.
This is a big mystery - would love any help any of you might be able to offer.
Seeking wisdom...
Car is a 96 Limited 4Runner - original owner. 280k miles on it.
natasha69 is offline   Reply With QuoteReply With Quote
Old 10-07-2013, 12:50 AM #2
PitbullRescuer's Avatar
PitbullRescuer PitbullRescuer is offline
PitbullRescuer is on a distinguished road
It didn't consume that much fuel. The gas gauges in these things are notoriously inaccurate.
'98 SR5 4x4, cheap DD http://www.toyota-4runner.org/3rd-ge...im-addict.html '99 SR5 Highlander 4x4/5 Speed... http://www.toyota-4runner.org/3rd-ge...eed-build.html '97 SR5 4x4/5 speed, another new project... http://www.toyota-4runner.org/3rd-ge...new-build.html '00 SR5 4x4, new project, stay tuned... http://www.toyota-4runner.org/3rd-ge...ld-thread.html '97 Limited 4x4, freshened up quite a bit... http://www.toyota-4runner.org/3rd-ge...d-3rd-gen.html '99 SR5 Highlander 4x4... http://www.toyota-4runner.org/3rd-ge...ce-thread.html
PitbullRescuer is offline   Reply With QuoteReply With Quote
Old 10-07-2013, 12:52 AM #3
tomato_racing tomato_racing is offline
tomato_racing is an unknown quantity at this point
Sounds to me like a ground is loose for the fuel gauge sending unit or something. If you were actually using that much fuel it would be pouring smoke and probably be at risk of washing out the cylinders. I doubt it would run well if at all.
tomato_racing is offline   Reply With QuoteReply With Quote
Old 10-07-2013, 01:10 AM #4
Only issue is that I had the same situation last week. I filled up the car. A day later I drove to work (10 miles away) and back home. The gauge dropped from full to nearly empty. I went to the gas station and filled up the car (15 gallons).
Car runs fine. Nothing abnormal.
That's why I suspected a mysterious leak.
Besides a bad gauge any other ideas? This is pretty frustrating.
Thanks.
Old 10-07-2013, 01:20 AM #5
It sure as shit isn't consuming it. If it leaked 15 gallons in 10 miles, the source of the leak should be blatantly obvious.
Old 10-07-2013, 01:36 AM #6
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
I wouldn't smoke next to your truck lol
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 10-07-2013, 01:43 AM #7
Chandler_Ross's Avatar
Chandler_Ross Chandler_Ross is offline
Real Name: Chandler
Chandler_Ross is on a distinguished road
Real Name: Chandler
My guess is there's someone hiding under the car that comes out while your driving and syphons all your gas out.
But realistically, the situation you're describing just doesn't happen. If it is seriously that bad and you're thinking theres a leak somewhere, have someone follow behind you and watch for leaks. A tank of gas doesn't just disappear in 10 miles. Nor do cars burn enough gas under any circumstance for this to happen. If so, I wouldn't ever drive the thing again.
1997 Natural White 4Runner V6 SR5 4x4 165xxx mi. "Woody"
2.5" RC/Cornfed Lift, 1" Toytec BL, 285/75 Treadwright Guard Dogs, MagnaFlow
My Newly Updated Build/Timeline http://www.toyota-4runner.org/3rd-ge...-timeline.html
"Stay hungry, stay foolish." -Steven Paul Jobs 1955-2011
Chandler_Ross is offline   Reply With QuoteReply With Quote
Old 10-07-2013, 02:14 AM #8
20 miles (10 there, 10 back), but same difference.
Agreed on all points - that is why this is frustrating. I thought someone might be syphoning my tank and the gauge was catching up on the drive there and back - which is probably the only rational explanation. Until I went to the mechanic. He found no leaks, however when I dropped it off it had a full tank. When I drove home, I watched the gauge drop by a 1/4 tank. Really a huge mystery here.
The next step will be to fill the tank, drive the two miles, fill it again and see the actual volume of the fuel that is disappearing over that distance.
Old 10-07-2013, 07:25 AM #9
wc11's Avatar
wc11 wc11 is offline
wc11 will become famous soon enough
wc11's Avatar
Not likely a leak as that would be pretty obvious to see & smell.
Check to see if your hand brake or either front caliper is sticking. One side or both would cause a lot of drag.
wc11 is offline   Reply With QuoteReply With Quote
Old 10-07-2013, 09:05 AM #10
Not a chance in hell this is the issue here. The OP is getting about 1 MPG.
Old 10-07-2013, 09:32 AM #11
nissanh nissanh is offline
Where do you part your truck? Is someone stealing your gas?
Old 10-07-2013, 02:46 PM #12
driveway. i have security cams up which i was going to check. however, the car was parked at the mechanics shop over the weekend - experienced same symptoms, so i think i can rule out syphoning.
i'm going to fill the tank up, then drive 5 miles, and fill up the tank again. that will give a very clear picture if the gasoline is disappearing during the drive or when its parked. Will report back once that test is done.
Old 10-07-2013, 03:55 PM #13
chadsy chadsy is offline
chadsy is on a distinguished road
Going to sound silly but are you using Unleaded gas? I know some stations sell the ethanol heavy stuff which could decrease your gas mileage. Like someone else mentioned earlier, these gas gauges are pretty crappy.
1996 4Runner SR5 4x4 / 275,000 Miles / All Stock
chadsy is offline   Reply With QuoteReply With Quote
Old 10-07-2013, 04:05 PM #14
the entire tank is disappearing, so pretty sure thats not it. we fill up at chevron, so no ethanol. yes, for the 96, we are using regular unleaded. but highly doubtful that is the issue.
Old 10-07-2013, 04:23 PM #15
snivilous's Avatar
snivilous snivilous is offline
snivilous will become famous soon enough snivilous will become famous soon enough
snivilous's Avatar
Well IF there is a leak, and it's not enough to just leak when it's sitting parked, then let the truck idle and massage the throttle while parked. If you are actually leaking somewhere while under load (perhaps from a hose) then it'll start pouring on the ground.
I assume you've already crawled under it yourself to see that there is no visible leaks from the tank or hoses forward of the tank, or over the front bash plate?
snivilous is offline   Reply With QuoteReply With Quote
Fuel consumption error - Maint light reset adam5oh 4th Gen T4Rs 2 12-23-2020 08:46 PM
Fuel Consumption Surge, Possible Reasons? raminux 4th Gen T4Rs 12 08-03-2013 12:55 PM
Improving on 12mpg fuel consumption duffbeer911 3rd gen T4Rs 3 07-17-2012 09:55 AM
Horrible fuel consumption problem! Brand X Classic T4Rs 0 01-12-2010 12:02 AM
Question fuel consumption W211_to_T4R 4th Gen T4Rs 10 07-20-2008 01:33 PM
